Pulling factory steering wheel help!!!
Old Mar 19, 2022 | 08:51 AM
Keev1414's Avatar
Keev1414
2017 C5 of the Year Finalist
Default Pulling factory steering wheel help!!!
I have watched every video on YouTube. Bought a J leg puller from O reilys didn't work!! Rented auto zones master mechanic puller kit didn't work!! All it does is sheer off the metal.
any helpful hints or direction for me???
thxs for any replies!!!
Old Mar 19, 2022 | 10:00 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Damn man I've heard these stories.
Sorry don't have any experience with it because my wheel popped off after a minute of cranking the bolt
Old Mar 19, 2022 | 10:03 AM
Keev1414's Avatar
Keev1414
That's the exact puller I tried x 2. No luck 😪!!!
Old Mar 19, 2022 | 10:10 AM
feeder82's Avatar
feeder82
https://www.corvetteforum.com/forums...asier-way.html
Try this puller
Old Mar 19, 2022 | 10:14 AM
Cutlassmaster's Avatar
Cutlassmaster
I had the same issue on my buddies car. I ended up drilling holes and tapping them. When I was trying to pull it that way, it almost broke the grade 8 bolts I was using. It finally popped. What a pain. Search and you will see where others have had to do the same thing.
Old Mar 19, 2022 | 10:16 AM
Life’s good C5's Avatar
Life’s good C5
I tried pullers and they didn’t work and was about to give up and read a thread here that suggested to use a sledgehammer on opposing sides. As a last ditch effort I did that and with the last blow “boing” it broke loose. Just my 2 cents.
Old Mar 19, 2022 | 10:34 AM
rrwirsi's Avatar
rrwirsi
Duck tape, screw drivers, and now sledgehammers fix the world.
Old Mar 19, 2022 | 10:39 AM
Old School's Avatar
Old School
I soaked mine with penetrating oil for two weeks. Not sure this did much, still needed a lot of force to get it to pop. I used those J-hooks and they gripped well but I really though the steering wheel was going to break.
Old Mar 19, 2022 | 11:00 AM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Without a doubt, they can be very hard to get off. I used the J hooks and soaked it over night with penetrating oil. The next morning, I slowly started cranking on it, while shocking it with a hammer strike. I ended up having to put a bar through the steering wheel to keep it from rotating while I continued to crank down with my breaker bar. Finally, there was a LOUD pop (and I damn near crapped my pants) and to my surprise, it popped off! Based on some of the other stories I have read, you may end up being one of those that will need to cut it off...unfortunately...
Old Mar 19, 2022 | 12:51 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
What I'd do next is drill and tap the wheel. I gave up on mine as I didn't have the correct puller for the bolt type so my body shop finally did it for me. He did use a hammer with it also. When it does pop off, it will make a loud sound like something broke. Don't worry though, hopefully it will be just the sound of the wheel letting loose. Good luck.
Old Mar 19, 2022 | 01:01 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Drill and tap.
This was the biggest nightmare for me, too. I ended up swapping my whole column out. It was just easier.
Pulling the wheel was the worst job I've done on the car - and I've done a lot to my car. Sorry it's being such a bastard.
Old Mar 19, 2022 | 01:02 PM
Keev1414's Avatar
Keev1414
Thxs for all the info!! I'm going to try the 3 prong puller. Do I have to pull the plastic shroud behind the wheel??
Old Mar 20, 2022 | 12:23 PM
Keev1414's Avatar
Keev1414
Ok. I bought Oem tools 2 ton 3 prong puller Model # 25901.
I'm off on Wednesday.
Round 3 of getting wheel off
Old Mar 20, 2022 | 12:53 PM
C6_Racer_X's Avatar
C6_Racer_X
Always difficult. On most any vehicle.
  • Soak the spline area with penetrant. PB Blaster or Kroll are best in my experience. Doing this a day or two in advance helps. Soak it daily.
  • Grease the threads on the puller jack screw. Use quality high pressure grease.
  • Grease the tip of the puller jack screw that contacts the shaft. Also grease where the end of the screw goes in that tip piece.
  • Use an impact type socket if you have one.
  • Once the jack screw is tight and the puller hooks are in tension, hit the socket on top of the jack screw with a heavy hammer a couple times, like you're trying to drive the shaft and the jack screw through the center of the wheel, then turn it a quarter turn or so and hit it again with the hammer. Vibrations help loosen things. Repeat until it sounds like something breaks. Hopefully it's the wheel coming loose from the shaft.
Old Mar 20, 2022 | 02:04 PM
Keev1414's Avatar
Keev1414
Goods tips !!! thx u!
Old Mar 22, 2022 | 12:03 PM
Moved to C5 Tech.
Old Mar 22, 2022 | 01:46 PM
MWWarlord's Avatar
MWWarlord
If you've already pulled through the metal with the other pullers, you'll likely have to go to the drill and tap method. Given all the horror stories, I paid my mechanic to pull mine. It took 2 guys with a wheel puller. 2 screw drivers, and a hammer 45 minutes to get the old wheel off. It was worth every penny I paid them to not have to deal with that myself.
Check out post # 120 in the thread linked below. https://www.corvetteforum.com/forums...g-wheel-6.html
To Pulling factory steering wheel help!!!
Old Mar 22, 2022 | 01:53 PM
Keev1414's Avatar
Keev1414
I am trying the 3 prong gear puller tomorrow.
Old Mar 22, 2022 | 11:10 PM
Bruss's Avatar
Bruss
Good luck tomorrow! I predict you will be succesfu.
Old Mar 27, 2022 | 06:46 AM
Keev1414's Avatar
Keev1414
Ok puller worked no Problem!!!! If J leg puller doesn't work. Use Oem tools 2 ton puller Model # 25091.
