Linkage / trans cycle gears
Old Mar 19, 2022 | 08:38 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Linkage / trans cycle gears
When attaching the linkage to a fresh t56 or 6060, should you be able to rotate the linkage left/right between gears? The nub the linkage attaches to only seems to go in and out, no rotation. I'm not about to force it. Haven't connected the shifter yet.
Old Mar 20, 2022 | 01:10 AM
Moved to C5 Tech.
Old Mar 20, 2022 | 01:19 AM
Tusc's Avatar
Tusc
Once I got the linkage connected right I figured it out. There seems to be a middle ground in the travel where you can shift gears. Without the shifter and linkage set to that neutral point the arm only shifts it dull forward or back. This one works fine. But dang does it seem loud when shifted so far.
To Linkage / trans cycle gears
