Light grinding, RPM dependent
Old Mar 23, 2022 | 11:59 AM
DallasLoneStar's Avatar
DallasLoneStar
Default Light grinding, RPM dependent
Having some light grinding / scratchy sound from the engine bay. RPM dependent so I assume it is something on the serpentine belt. What is the usual suspect on these? New to LS world so sorry this is so basic. And yes, I did a forum search first.
Old Mar 23, 2022 | 02:49 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Tensioner would be my first suspect.
Fairly easy to remove the belt and turn components by hand.
Old Mar 23, 2022 | 08:12 PM
Americal's Avatar
Americal
Balancer walking back to the timing cover?
Old Mar 23, 2022 | 10:04 PM
DallasLoneStar
Will investigate this weekend and report back. Working a ton this week. Just ordered an automotive stethoscope, will arrive on Friday
Old Mar 24, 2022 | 08:56 AM
Johnny Hardcore's Avatar
Johnny Hardcore
That will definitely come in handy. As does a borescope handheld device.
The RPM dependent noise is when moving or stationary? If it's stationary that rules out wheel hubs. Then focus on pullys.
Harmonic balancer as mentioned above is a known failure point. The tensioner, water pump, alternator and AC compressor is also where I would look first.
Also mentioned above the belt is easy on and off (if your car is not FI). So isolating issue with belt off will help rule out pullys.
Old Mar 26, 2022 | 11:51 AM
Moved to C5 Tech.
To Light grinding, RPM dependent
