50th Anniversary front shocks
Old Mar 23, 2022 | 01:35 PM
Mike2003's Avatar
Mike2003
Navigator
Default 50th Anniversary front shocks
Anyone know the proper front shocks for my 2003 50th anniversary edition and suggestion as to best place to buy them. 1st state Chevrolet here says they are over $800 a piece. Rockauto says $95. Confused????
Old Mar 24, 2022 | 11:32 AM
Simtech's Avatar
Simtech
You probably have the Magnetic Ride shocks. They are very expensive. My 2003 just had the base suspension so I upgraded to the C6 Z06 shocks. Shock Absorber Front PN:10313647
Old Mar 24, 2022 | 11:58 AM
03 Owner's Avatar
03 Owner
You have the F55 shocks. Rock Auto has them for around 400 each. Both fronts shocks are the same, the rears are different part numbers.
Old Mar 24, 2022 | 12:38 PM
STRMLNE's Avatar
STRMLNE
Just because you have magnetic ride doesn’t mean you have to replace them. Many people just put in base shocks or c6z shocks (both direct replacements) and then have a tuner eliminate the code for mag ride. Good way to save a ton of money.
Old Mar 24, 2022 | 01:13 PM
grinder11's Avatar
grinder11
He should have the F55! To the best of my knowledge, ALL 50th Anniversary models came with the F55 as std. equipment.......
Old Mar 25, 2022 | 03:18 PM
Mike2003's Avatar
Mike2003
Navigator
Thanks everyone. I bought the F55 from Rockauto for $391. Expensive but it’s correct for the car. You guys are a wealth of knowledge.
Old Mar 25, 2022 | 03:22 PM
STRMLNE's Avatar
STRMLNE
Make sure you do the pair for the axle
Old Mar 25, 2022 | 04:01 PM
Mike2003's Avatar
Mike2003
Navigator
What does do the pair for the axles mean? Are you talking about the rear?
Old Mar 25, 2022 | 05:43 PM
STRMLNE's Avatar
STRMLNE
always replace the pair per axle!
To 50th Anniversary front shocks
