column lock circuit code from lcm5
Old Mar 27, 2022 | 06:21 AM
Justin Raney's Avatar
Justin Raney
Default column lock circuit code from lcm5
Will installing the lcm5 which in the instructions tells you to remove the column lock relay above the module set off a dtc code?
Heres what i have. WIll removing the steering column lock relay above bcm when installing lcm5 cause these codes? I removed the relay but i can plug it back in if itll get rid of these 2 codes. I do have the vats column lock vss turned up to 200mph.
B2588 Column lock open or short to voltage
B2593 Column unlock open or short to voltage
