So when I was doing my LS3 swap I just cut my C5 upper radiator hose and spliced in a section of pipe to give the extra length I needed. It was admittedly an inelegant solution, but it worked at the time.
Well, it has started to weep a bit from that splice, and I'm thinking of replacing it to eliminate the splice. If I were to buy a hose for an LS3 C6 would that be the right dimensions and configuration to work with a C5, or would I be right back in splice city with the new hose?
