New wheel fitment
Old Apr 12, 2022 | 05:52 PM
HandOverFist's Avatar
HandOverFist
Default New wheel fitment
Seeing as the current set of tires are 6 years old and I'm not really liking the current wheels it seems a good time to consider options. Eyeballing these for the '98... https://www.ebay.com/itm/38423541461...2Cchnl%3Dmkcid
Does anyone see a fitment issue with these?
Old Apr 12, 2022 | 05:55 PM
STRMLNE's Avatar
STRMLNE
I would ask the seller this question and see if any spacers are needed etc. That way if you have any issues, you have a paper trail for a return.
Old Apr 12, 2022 | 06:05 PM
HandOverFist
I have sent a message already. I'm not clear about the factory offsets on these cars.
Old Apr 12, 2022 | 06:17 PM
STRMLNE's Avatar
STRMLNE
Found this on google for you !!
https://image.mamotorworksmedia.com/...ce_Guide-a.pdf
Old Apr 12, 2022 | 06:31 PM
HandOverFist
The offsets appear to be very close. I need to know the backspacing though.
Old Apr 12, 2022 | 07:09 PM
lionelhutz's Avatar
lionelhutz
With offset and width you can calculate backspacing. Look online for a calculator.
Old Apr 12, 2022 | 07:17 PM
HandOverFist
I just tried one and the results using the factory figures come up almost a 1/2" greater...not comforting. This is the reasoning behind my questions here on this forum. Ask me about wheels for mid-60's vehicles and I can probably tell you what's needed off the top of my head. I don't have much experience with the newer vehicles. Much better to get input from someone who has a similar vehicle and has tried different combinations.
Old Apr 12, 2022 | 09:49 PM
HandOverFist
Vendor just replied and the backspace is 7.38". I elected to use (4) 18x9.5 wheels all around. I suppose there isnt much sense in going back with the TPM sensors if I plan to rotate these tires.
Old Apr 12, 2022 | 10:01 PM
lionelhutz's Avatar
lionelhutz
Well, same offset with 1" more width makes for 1/2" more backspacing.
Why no TPMS? It's really easy to reprogram them when you move the wheels.
Old Apr 12, 2022 | 10:53 PM
HandOverFist
Mostly because I'm not a big fan of the things...I suppose I can just transfer them tho to save the cost of different valve stems. I'll wait until they are in hand before deciding on tires. Appears 275/35R18's all around will keep them close to the same overall diameter I have now. If there is no poke on the fronts I would love to go with a 40 series with a little more diameter.
Old Apr 13, 2022 | 12:44 PM
lionelhutz's Avatar
lionelhutz
Well, same size wheels the ABS and TC and AH if you have it won't work right either.
Old Apr 13, 2022 | 01:29 PM
HandOverFist
I've heard it both ways. Who knows how long those things will continue to operate with these junky cars anyway?
To New wheel fitment
