#@%# Fouled Plugs Again
Old Dec 31, 2002 | 04:43 PM
BLACKONBLACKZ06's Avatar
BLACKONBLACKZ06
Default #@%# Fouled Plugs Again
10K miles on the engine since rebuild...heads, cam, pistons etc.
The first time it happened was at 100 miles with racing plugs originally...
They then replace the plugs with stock and the car had been running
perfectly.... until last night....
Does that seem normal with a H/C setup?
Is there a better/hotter plug?
:seeya
Old Dec 31, 2002 | 05:13 PM
C5Noir's Avatar
C5Noir
Default Re: #@%# Fouled Plugs Again (BLACK/BLACKZ06)
Sounds like you're WAY rich on the A/F. Can you atap it for us and tell us what your LTRIMs and WOT O2 readings are?
Old Dec 31, 2002 | 07:00 PM
Avanti's Avatar
Avanti
Default Re: #@%# Fouled Plugs Again (C5Noir)
...or just put in the next hotter heat range, and if they melt you'll know they weren't right! :yesnod: But, seriously--unless you are running under serious load for longer periods you may find a hypo engine needs a warmer STREET plug. Don't forget to change to a colder one for competition, though. I've raced engines that had to be warmed up with a "hot" plug and cold ones swapped in before competing.
BTW, 10K on plugs in a competition engine is not bad, at all.
All the best and HAPPY NEW YEARs! :cheers:
[Modified by Avanti, 6:01 PM 12/31/2002]
Old Dec 31, 2002 | 08:44 PM
MelloYellow's Avatar
MelloYellow
Default Re: #@%# Fouled Plugs Again (Avanti)
Which plugs?
Gap?
Which MAF?
Old Jan 3, 2003 | 05:48 PM
BLACKONBLACKZ06
OK... :crazy:
After reading several articles here and there...sounds like the NGK TR6
plug is what I should be using....
The Question is "what gap should I start at?"... :thumbs:
[Modified by BLACK/BLACKZ06, 4:52 PM 1/3/2003]
Old Jan 4, 2003 | 12:51 PM
lost's Avatar
lost
I thought someone would have pointed out that the TR6 is one range colder than the standard replacement TR55.
Old Jan 4, 2003 | 09:31 PM
BLACKONBLACKZ06
Default Re: #@%# Fouled Plugs Again (lost)
Dang....No problem changing out the plugs....butttt
After removing all the plugs #3 was fouled really bad and Thought I had it made...After installing the TR6 the engine was still running like SHi#
So off I go to get a set of stock plugs gap @ .055...installed and the engine still runs bad. By this time changing the plugs is a snap :lol:
Let it run for a few min. and pulled #3 and it was soaked...
Guess which valve spring i'm using?
I had a 941 break before and afraid thats what it is this time also...
Old Jan 5, 2003 | 12:00 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
guys where can i find out about heat ranges & plugs?? id liek to know, i havnt really searched but it dont say on the packages/boxes ... or does it?
plugs im interested about are the accel u -groove and the bosch +4.
To #@%# Fouled Plugs Again
