Overheating !!
I seen people say 220 is normal but smoking behind the engine to me ain't. If someone can help a, give any tips or give me an idea 💡 it be gladly appreciated
It's white smoke , and fans turn on keeping it from going over 235 but from videos and other forums im guessing head gasket or heater core either one is gonna be expensive lol
Find a good mechanic or dealership in your area and get it diagnosed and get an estimate on repairs. If it’s a head gasket and there is no further damage, then you can address the heat issue. An oil change should be done as well if it is a head gasket, to ensure any coolant is removed from the oil.
Maybe you need a lower temp thermostat and to program your fans to come on at lower temps. With only the info provided, no one is going to be able to figure out why it’s running that hot. Not knowing the ambient temps this is happening at, and highway vs. stop and go, and those type factors all need to be known to assess the heat issue.
But you mentioned that your temp goes up to 235, the secondary fan comes on and it starts to cool down a bit. Your primary fan should be running when your A/C is turned on. Maybe turn on the air, and lift the hood to make sure one of the fans is running continuously. If no fan is running it could the primary fan is kaput.
Hope this helps........
The next thing I am wondering, since you have a new radiator, condenser, water pump, and thermostat is, is your center air deflector underneath possibly worn out. Not knowing anything about your car like, mileage, ownership, etc, but does the center air deflector scrape a lot when entering and exiting driveways and businesses? In time these will wear enough material off to grab less and less air. All your cooling when moving over 35 mph depends on that center air deflector feeding proper air flow to the radiator and condenser. The center air deflector is a very inexpensive part, and is very easy to replace with the front of the car on jack stands, if you don't have a lift.
I just recently solved heating issues with my car, but my issues were due to modifications that were restricting proper air flow and a defective device I purchased to remotely control the fans. I had to address one issue at a time to figure out the cause, and I recommend that you do the same. If not, you are just throwing money at it until you eventually hit the cause. With what you have already done, I would certainly be looking at that center air deflector, as it sounds like an air flow issue, with the limited information known. It certainly should not be running that hot in 78 degree ambient temps, with or without the AC on.
Do you see bubbles in your overflow tank while the car is running at operating temperature? If so, that's a bad sign. You can buy a test kit that will show if exhaust gasses are getting into the coolant system. If so, it's almost certainly a head gasket. If you're not seeing coolant fouling in your oil that's a good sign that the failure is just contained to the head gasket, but either way it needs to be replaced.
Head gaskets on these cars is certainly a job, but it's not insurmountable and definitely not "sell the car" kind of bad unless you're looking to get rid of the car anyway. It can be done in an afternoon by someone who knows what they are doing. You'll need a new set of head gaskets, and a new set of head bolts, but other than that it's a matter or getting the heads off, cleaning everything up, and putting the new gaskets on. DO NOT RE-USE THE HEAD BOLTS, NO MATTER HOW "GOOD" THEY MIGHT LOOK.
Has the OP verified both speeds are working?
I had an issue with an old Audi 1.8T of mine, where there was a crack which formed between a valve seat and cooling jacket. When the car was hot, combustion gases would escape through the crack and enter the cooling system, thus aerating the cooling system + over-pressurizing it.
In the case of a head gasket issue you might also see coolant being drawn into the combustion chamber, resulting in white smoke as the coolant burns.
