Non-essential "essentials?"........
Old Apr 19, 2022 | 02:15 PM
grinder11's Avatar
grinder11
Default Non-essential "essentials?"........
My post is probably going to be controversial, but here goes......
I'm seeing many posts about changing out the brake fluid every 2 or 3 years. Apparently it's because brake fluid is hydrophilic? IDK, but I have NEVER changed brake fluid in any vehicle I've ever owned, including my 22 year old C5. Mind you, I put 360,000 miles on a '95 Grand Cherokee without doing it. I put 399,000 miles on my '03 LeSabre without changing it. Any vehicle I have ever owned has had the same brake fluid GM filled it with on the assembly line. I've also never had any issues with my brakes, other than normal pad and rotor changes. Why is this so "essential", when I've never done it, and never had issues? Isn't the brake system sealed? How would water get in it if nothing has been disturbed? While I'm at it, I've never changed a fuel filter, either, except the old school brass particle type in a quadrajet, after some bad gas. I really believe the public is being hosed into a lot of non-essential "essentials!!" It can't all be luck. Any thoughts???
Old Apr 19, 2022 | 02:28 PM
rrwirsi's Avatar
rrwirsi
OK, I may be the first to respond. It may be just habit and old school. When I was doing all the DIY stuff to cars, it was a must by mechanics recommendations that when brakes were replaced, the fluid needs to be changed or at 5000 miles.
Old Apr 19, 2022 | 09:27 PM
Ed Ramberger's Avatar
Ed Ramberger
Hey Grinder, it's actually hygroscopic. It can be really bad on some systems. HD actually had a lot of antilock systems failing because of it. When I lived up north, the brake fluid in my cars definitely seemed to stay clearer longer than down here in the south where it's like soup outside in the summer. Agreed some of it is service marketing, but I do believe that now that practically every car has antilock, it's an extra measure to make sure that the ABS pumps live as long as possible.
I guess that you and I have lived different equipment lives. I spend a ton of time around EFI and common rail diesel, and failure to change fuel filters kills many VERY expensive systems. Nothing like replacing a $7k fuel system because of lack of maint!
Old Apr 19, 2022 | 11:50 PM
My Vette Life's Avatar
My Vette Life
Sheeeesh Q jet FTW
I was so close to stick a carburetor and an edelbrock intake on my ls
Old Apr 20, 2022 | 12:09 AM
vette4fl's Avatar
vette4fl
Grinder, I believe you’re just lucky.
Sometimes chemistry and physics play games with us. For example, I used to change the oil in my gas mower twice a year, whereas my two neighbors never even checked the oil in their mowers. Their mowers ran forever and mine always had issues…? So, I finally got the message from the universe and just filled it with gas and ran it. Never changed the oil, or air filter again. The damn thing ran great from then on!
Old Apr 20, 2022 | 12:45 AM
jim993's Avatar
jim993
It is all because of heat. If you don't track your car, old brake fluid is just corrosive*, not otherwise very hazardous.
All brake fluids have both wet and dry boiling points. On the street you almost* never get your brake pads or caliper pistons very hot and in that case those brake components do not get hot enough to boil the moisture in the brake fluid.
On track is very different. Typically on track you are braking from 70 to 120+ MPH down to 30 or 40-- fifteen times per lap for ten or more laps in 20 minutes. Front brake rotor temperature is often near 700 degrees F. If the moisture in the brake fluid boils, most braking authority is lost.
Typical racing brake fluid has a wet boiling point of just below 400 degrees F and a dry boiling point of near 600. Standard DOT 3 fluid is much lower. Dry, clean brake fluid is FASTER and safer on track.
* Unless you are an idiot and drag your brakes down a long grade-
Old Apr 20, 2022 | 03:25 AM
RedC5's Avatar
RedC5
I did my ‘98 once speed bleeders at about 40 or 50K probably 5 years ago. The fluid bleed was crappy black initially coming out from contamination in caliper— so nice to get this out of system. I probably won’t do mine again for many years. 69k now.
Old Apr 20, 2022 | 09:21 AM
grinder11's Avatar
grinder11
Thanks for the English correction, Ed! I had forgotten the terminology, and Googled it, and it came back what I posted. I believe your terminology is correct, however. Anyway, we aren't that different. I do believe in preventive maintenance. As for the fuel filter, wouldn't the filter fail by plugging up, and the engine would start running rough? If not, please advise?
Old Apr 20, 2022 | 10:23 AM
grinder11's Avatar
grinder11
Thank you for your response. I think youve probably pinpointed the reason my brake fluid has lived. The only time any of the brakes have been worked harder than normal would be descending the Smoky Mountain grades between Cherokee NC, and Gatlinburg TN, and even then, I descended using a lower gear, like 2nd, and rarely, sometimes 1st. My C5 has never been tracked, other than maybe 50 dragstrip runs, and even then, the brakes are only used hard for maybe 5-10seconds, max. The fuel filters, I have no reason they've lasted so long.....
Old Apr 20, 2022 | 10:33 AM
grinder11's Avatar
grinder11
Thanks, jim993. I never knew old brake fluid got corrosive. I know old antifreeze gets acidic, and starts destroying the cooling system after around 5 years. I guess the PH changes. If thats the case with brake fluid, I'm going to change it. I just hate messing with it, because of the EBCM being non repairable on the '97-'00 models, and mine still works, right now, this minute! Kind of a "if it aint broke, dont fix it" attitude. But I dont believe in ostracizing a potential problem, either. Thats why I pulled my LS7 heads, and its a good thing I did!!
Old Apr 20, 2022 | 12:07 PM
jim993's Avatar
jim993
Checking my log, in a week or so, I will flush brakes for the 8th time in 13 years while getting ready for Arizona Motorsports Park on May7. Never an issue with the EBCM.
I have found that the easiest, fastest way to flush is to install speed bleeders and pump the pedal, being careful not to let the master cylinder get low. FSM order = RR LF LR RF. Get hoses, used fluid container ready ahead of time.
For MY car, 20 pedal pumps each rear, 15 pedal pumps each front = about one liter of fluid. Start by syringing the old fluid out of the master cylinder and replacing with new before pumping each wheel.
DO NOT get any fluid on exterior paint, new or old it is very corrosive on paint.
Old Apr 21, 2022 | 09:26 AM
Gordy M's Avatar
Gordy M
Why do I change my brake fluid at least two or three times a year, because I make between 225-250 autocross runs a year and a few track days as well. Listening to Kellermeyer and Heinracy I know that brake absorbs moisture and you should change it first thing before running it every year. But what do they know.
Old Apr 21, 2022 | 02:35 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
By its chemical nature, brake fluid will absorb moisture from the air. This is known as being "hydroscopic". This happens because the master cylinder reservoir isn't entirely sealed, and there is some air in there that contains moisture.
This usually isn't a problem for street driving, however, is a MAJOR problem in high-demand instances like track or mountain driving where you're putting a lot of heat into the brakes. Water isn't compressible, so at below 212F/100C the water in the brake fluid remains liquid and works pretty much like the rest of the brake fluid. Once you get the fluid above the boiling point of water those little water molecules become tiny steam bubbles. Steam is very much compressible and will act just like having air in your brake lines. This can lead to a long or non-existent brake pedal.
Old Apr 21, 2022 | 02:42 PM
Ed Ramberger
Originally Posted by Napoleon_Tanerite
By its chemical nature, brake fluid will absorb moisture from the air. This is known as being "hyGroscopic".
Definition police - corrected lol
Old Apr 21, 2022 | 07:18 PM
Old School's Avatar
Old School
Note to self - don't buy a used car from Grinder
Old Apr 21, 2022 | 07:23 PM
Napoleon_Tanerite
If he wasn't such an old and established account I'd be convinced he was a troll with some of the stuff he's been posting lately, such as shaving brake rotors
Old Apr 22, 2022 | 08:30 AM
RPGR90s's Avatar
RPGR90s
As others have explained, it's hygroscopic, meaning that it absorbs water. Specifically, DOT3, DOT4. DOT5 is silicone based and is less susceptible to water intrusion and should NEVER, EVER be introduced into a system using DOT 3, 4.
Quick story. Taught as a kid growing up with the old man to bleed the brakes each fall in the family car to get new fluid into the system. The 'ol man was always proud that the brake fluid was "clear" in the master cylinder and I can't think of a single brake related issue in all those Ford station wagon's I grew up with.
So in 1980 I buy a BMW motorcycle with dual front discs ('74 R90s) and over the next thirty years continue changing out the brake fluid each season. So about ten years ago I decide to take the calipers apart because they're old as hell AND the bike has over 100,000 miles. When I popped the pistons, the bore and piston surfaces were literally like new. It was pretty amazing, actually. So I put in new seals and buttoned it up.
That's why I change my fluid annually in all my vehicles.
To Non-essential "essentials?"........
Old Apr 22, 2022 | 02:21 PM
grinder11's Avatar
grinder11
Old Apr 22, 2022 | 02:26 PM
grinder11's Avatar
grinder11
In all honesty, if I was still working at the shop, I'd probably at least try the theory on an older set of rotors. This.......From a guy who doesn't worry about running 23 year old brake fluid, or 23 year old fuel filters, but worries about taking a couple 3 ounces off his rotor weight. Reminds me of that old radio jingle "Theyre coming to take me away, ha ha, he he........
OK, you guys have shamed me!! When I get home, I'm going to buy some speed bleeders, brake fluid, and a new fuel filter. As long as I'm going to go to the trouble of buying brake fluid, and flushing the system, will this flush and bleed the EBCM, too? I don't have a Tech 2, so.......
Old Apr 22, 2022 | 04:20 PM
jim993's Avatar
jim993
It won't bleed the EBCM , but after your flush, go out and make some stops hard enough to activate the anti skid. That will flush some of the new fluid through the ECBM. After that if the master cylinder fluid gets cloudy, syringe it out and replace.
For you, a good practice would be to syringe out and replace the master cylinder fluid every oil change or once a year whichever comes first. At the same time do that to the power steering fluid reservoir with full synthetic PS fluid like Red Line. Use a different syringe for PS fluid-
