No Key Start
Old Apr 22, 2022 | 11:44 AM
StandardZ's Avatar
StandardZ
Default No Key Start
Any way to bypass the ignition to start the engine? I bought a damaged Z06 without keys at auction. I want to check that the engine runs before i pull it.
Old Apr 22, 2022 | 12:23 PM
mmartinez's Avatar
mmartinez
Easiest thing to do is have a key made by using the Vin, there is no easy way, you can crank the engine over by jumpering at the TDR, but it will not start.
Old Apr 23, 2022 | 01:04 AM
lionelhutz's Avatar
lionelhutz
Hook a resistor to the VATS wires and jumper out the ignition switch connector to be able to turn on power so you can do a VATS relearn then it'll start by jumping the right wires together at the ign switch connector.
Old May 4, 2022 | 04:38 PM
StandardZ's Avatar
StandardZ
Resolved: $31 key made a local Chevrolet dealer, just had to show title and ID.
Old May 4, 2022 | 06:12 PM
mmartinez's Avatar
mmartinez
That is the easiest way, did it start?
To No Key Start
