Propeller shaft bearings
Old Apr 22, 2022 | 01:42 PM
ncali's Avatar
ncali
Default Propeller shaft bearings
I am about to have my auto trans rebuilt at a shop' When they remove the trans, does the propeller shaft get pulled at the same time?
If it does I would like to have those bearings changed . Where can I find the bearings for that shaft?
Old Apr 22, 2022 | 01:51 PM
VetteMed's Avatar
VetteMed
Yes, the torque tube, which contains the shaft, is removed as part of removing the transmission.
Kits are available to rebuild, but there is a difference based on model year so be sure you order correctly.
Old Apr 22, 2022 | 02:18 PM
feeder82's Avatar
feeder82
No, the diff and transmission come out first, the torque tube can remain without having to come out. You can pull the whole drivetrain as a unit as seen in my avatar but for a tranny repair it's not necessary
Old Apr 22, 2022 | 03:21 PM
VetteMed's Avatar
VetteMed
I don't see how or why you would want to pull the trans without the torque tube. that seems much more difficult than it's worth. realignment on install also seems like it would be challenging.
Old Apr 22, 2022 | 03:33 PM
MetalMan2's Avatar
MetalMan2
I'm unsure how different torque tube installation is between manual and auto, but at least for manual I prefer torque tube first because it's easier to stab the TT input shaft into the clutch & pilot bearing and feel how it enters (so as to avoid damaging anything). Aligning the trans to TT with the TT installed first is inconsequential, IMO. [again, for manual, and I'm not fully aware how different it is for auto]
Old Apr 22, 2022 | 03:56 PM
VetteMed's Avatar
VetteMed
Interesting. This is the first I've heard of anyone doing it that way, but your reasons sound pretty good to me. I know I hate fighting with the whole drivetrain as I attempt to get the TT input shaft aligned in the clutch/pilot.
Old Apr 22, 2022 | 04:04 PM
feeder82's Avatar
feeder82
Without a couple helpers or a least one stabbing the whole drivetrain in one piece is not easy. Even on a hoist and tranny Jack
Old Apr 22, 2022 | 04:36 PM
VetteMed's Avatar
VetteMed
I did it by myself, laying on the floor, tranny jack, car on jackstands. I'm a glutton for punishment, apparently.
Old Apr 22, 2022 | 06:05 PM
MetalMan2's Avatar
MetalMan2
In my case it was only myself, Quick Jacks, and no trans jack (just a couple floor jacks, I'd get a trans jack for next time). With a trans jack I can imagine doing it all in one shot. Actually, now that I think about it, I bench-pressed the trans and had it in/out multiple times because of my linkage upgrade. Talk about a glutton for punishment?
Old Apr 23, 2022 | 01:23 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Lyle has what you need!
https://www.corvettepartscenter.com/...te-torque-tube
I bought my TT bearings & couplers from him and he did me right
Old Apr 23, 2022 | 07:47 PM
lionelhutz's Avatar
lionelhutz
You have to separate the transmission off the torque tube to rebuild the transmission. So, if I was the shop I'd leave the torque tube in the car unless the owner is paying me to work on it as well.
Old Apr 24, 2022 | 12:13 AM
vette4fl's Avatar
vette4fl
This would be the right time to consider a converter upgrade. Just say’n
To Propeller shaft bearings
