Unusual noise only when hot
Old Apr 25, 2022 | 05:38 PM
STRMLNE's Avatar
STRMLNE
Default Unusual noise only when hot
Recently got this noise but only when the motor is hot. In the video you can hear the high pitched noise cut in and out then stay constant. (To me it sounds more like white noise, speaker static, feedback, high pitch, which is unusual. Not your typical belt or pulley squeak.)
Car has all new OEM belts, pulleys, ati harmonic, and alternator. I just replaced the alternator again thinking that was the cause, but unfortunately not. Water pump fairly new.
I’ve sprayed the pulled and belts with water to try and get a pitch change but no luck.
Seems to be coming from the drivers side of the engine compartment but can’t be positive.
Has anyone ever heard something like this?
thanks!
Old Apr 26, 2022 | 08:33 AM
helga203's Avatar
helga203
Originally Posted by STRMLNE
https://youtube.com/shorts/vFTQIF3uWHU?feature=shareRecently got this noise but only when the motor is hot. In the video you can hear the high pitched noise cut in and out then stay constant. (To me it sounds more like white noise, speaker static, feedback, high pitch, which is unusual. Not your typical belt or pulley squeak.)
thanks!
wow never heard that before. i have no clue but get get a spray bottom and stay the belt so u can rule that out.
Old Apr 26, 2022 | 11:03 AM
STRMLNE's Avatar
STRMLNE
man, I sprayed so much water in the belts and pulleys they are sparkling clean. 😂 yeah. It’s strange. Almost like a metallic noise. Only thing I can think of is a bearing in the power steering pump. But that seems like a stretch.
Old Apr 26, 2022 | 11:17 AM
helga203's Avatar
helga203
If that is a bearing going bad, this would be the first for me in 40yr of changes bad bearing having that pitch sound.
I,been thinkingg and ia knoww the bearing r sealed but try some wd or what ever u have. Im just trying to give u some wierd advicee and one of them might work. grammer and sphell check is all over the place so if u can read let me know because evey time i fix it another freaks out anyway.
Just listened to it a few time. It might be a vaccum leak by the TB it got louder wen u got close to it. So i wood get 2 gallons of gas and prou it all on the TB and if it revs up u found ur problem but u might make another problem with a fire. Of starter , brakee or what ever is flamable
Old Apr 26, 2022 | 11:44 AM
STRMLNE's Avatar
STRMLNE
Yeah, I’m going to look for vaccuum leaks today. I removed the catch can hoping that was it but no luck either.
Old Apr 27, 2022 | 03:00 AM
Vette97sc's Avatar
Vette97sc
Did you try to run car without belt? You can do that couple seconds.
Old Apr 27, 2022 | 08:38 AM
oharal's Avatar
oharal
Yeah that was going to be my suggestion to remove the belt completely and see if it goes away.
Old Apr 27, 2022 | 10:34 AM
grinder11's Avatar
grinder11
These damn noises.......I have one when cold, that goes away when up to temp. Wish I could help, but I cant figure out my own noise.......
Old Apr 27, 2022 | 10:36 AM
STRMLNE's Avatar
STRMLNE
I will give that a shot today. Spent some time with it yesterday. When hot, the noise will go away if it idles shortly, but if I raise the rpm or rev the car, it comes back.
To Unusual noise only when hot
