pushrods. ⁉️
Old Apr 28, 2022 | 12:16 PM
link9a's Avatar
link9a
Default pushrods. ⁉️
Hi guys .so.... lam going to install PAC 1218 600" Lift Rated valve spring in 2003 convertible OEM Cam . Some guys they say you must to change the pushrods in same time is that right ? If yes which brand I must to go with that can go with PAC 1218 any suggest ?
Old Apr 28, 2022 | 12:31 PM
helga203's Avatar
helga203
Plug and play, if the heads where not milled or block deck. get started or get n touch with grinder hes loves to come out to help with the job. a lot people break bolts but its impossible for him to break bolts because he all always has a beer in hand.
Old Apr 28, 2022 | 04:23 PM
vette4fl's Avatar
vette4fl
Cam Motion told me any good 5/16 .080 chromoly pushrod would do the trick for these springs.
I opted for a bit more strength with BTR 11/32” .080 chromoly from the Summit site.
Old Apr 28, 2022 | 06:02 PM
grinder11's Avatar
grinder11
Good for you! Run the largest diameter PRs that will clear that you can......
Old Apr 28, 2022 | 08:42 PM
vette4fl's Avatar
vette4fl
With your input! Thank you…
To pushrods. ⁉️
