1998 ECM reprogramming
Old May 3, 2022 | 11:44 AM
HandOverFist's Avatar
HandOverFist
Default 1998 ECM reprogramming
I'm assuming that all the sensors run through the ECM...if not, please advise me.
Would it be possible to reprogram a ECM to delete a parameter/sensor such as TPMS? Would this stop the constant dash info reminder? I've done away with the TPM sensors in my new wheels and the dash info now shows a constant TPM malfunction error. Btw, my DIC is no longer functioning so I have no control whatsoever.
Old May 3, 2022 | 12:58 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by HandOverFist
I'm assuming that all the sensors run through the ECM...if not, please advise me.Looks like you’re pretty far away from me because it would take 5 minutes to do.
The TPMS delete can be done with a Tech 2 or any similar bidirectional scan tool…the PCM is not involved !!
Old May 3, 2022 | 01:08 PM
HandOverFist
From other threads I have gathered the Tech 2 only works on '01 - models up. All of the electrical glitches on these models make me less than enthusiastic, especially with no good workarounds.
Old May 3, 2022 | 01:39 PM
C5 Diag's Avatar
C5 Diag
No will work on any GM OBD2 models….I’ve used mine on a friends 98 a while back.
Old May 3, 2022 | 02:06 PM
HandOverFist
Would most repair shops have a scan tool that is capable of this or is a "Tech 2" the only option?
Old May 3, 2022 | 02:21 PM
C5 Diag's Avatar
C5 Diag
A shop should have a higher end bidirectional scan tool and if they don’t they should be selling hot dogs instead of fixing cars !!…my Snap On Verus Pro and Autel can do this !!
Old May 3, 2022 | 02:25 PM
HandOverFist
I'll shop around local then and see what can be done.
Old May 4, 2022 | 02:43 PM
HandOverFist
First shop I visited said they did not have that capability. I won't waste time with on site visits again...calling around for confirmation. Why do I feel I already know how this is going to pan out?
Funny how people question you on why in the world would you do that. Mostly from folks that grew up never knowing life without TPMS I guess lol. It was just a gimmick from the start as most know the vast majority of consumers have no clue when it comes to car maintenance.
Old May 4, 2022 | 11:16 PM
HandOverFist
3 strikes - All say it can't be done and one said it would be illegal to do so. Thought the law was in effect for 2007-up year models...
Old May 5, 2022 | 09:50 AM
Gordy M's Avatar
Gordy M
The TMPS sensor was part of the Non-Programmable 416 bits if information in the 1997-2000 PCM, 512K, in 2001 it was moved to the Programmable section of the PCM and a bi-directional scan tool could turn off the sensors input.
Old May 5, 2022 | 11:37 AM
HandOverFist
A lot of conflicting opinions on this subject...that is troubling. Don't know about any issues that might arise, but would a swap to a later year PCM be feasible?
Another confusing item - Is the mileage recorded in the dash cluster or the PCM?
Old May 5, 2022 | 02:58 PM
SilverC54me's Avatar
SilverC54me
For 1998 to 2000 the TPMS cannot be disabled. In 2001 the Z06 was introduced which did not have TPMS. So there was an option in the BCM for 2001+ to disable or enable TPMS. This option is not there in the 2000 or older cars.
Any Tech2 can do the change on the 2001+ cars. I do not know about the 3rd party scanners.
Gary
Old May 5, 2022 | 03:14 PM
HandOverFist
So, the final consensus is this '98 is screwed. Either put the sensors in or live with it as is.
Old May 5, 2022 | 05:56 PM
JWM's Avatar
JWM
Given the choice, I'd go with the tpm's
Old May 5, 2022 | 07:42 PM
HandOverFist
Nah...not going through all that until it's time for a tire change. With my driving habits that will be at least six years lol.
Old May 5, 2022 | 07:48 PM
Joshclifford84's Avatar
Joshclifford84
Put the sensors in pressurized containers and mount near the wheel wells. Also, they must make simulators for these....
Old May 5, 2022 | 08:31 PM
HandOverFist
Found a Vette shop nearby that says he can do it. I'll let you know if it happens.
To 1998 ECM reprogramming
