Electric Steering Won't Come Forward
Old May 3, 2022 | 09:06 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default Electric Steering Won't Come Forward
As the title says, I have a 99 with the electric steering wheel that won't come forward. I can move it back just fine, and the only way to get it to come forward is to hit the memory preset. Any ideas?
Old May 4, 2022 | 08:21 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Anyone?
Old May 4, 2022 | 08:33 PM
1999corvettels1's Avatar
1999corvettels1
If it works when using memory, sounds like the switch might be issue.
Need to test switch.
Old May 4, 2022 | 08:35 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Any codes in your diagnostic Instrument cluster?
Old May 4, 2022 | 11:21 PM
JMG2's Avatar
JMG2
Moderator
see this thread-- you can try resetting the switch:
Power telescoping steering column died!! - CorvetteForum - Chevrolet Corvette Forum Discussion
Old May 5, 2022 | 02:16 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Originally Posted by JMG2
Just tried it twice and no-go. I can live without it; I was just hoping there was an easy fix.
Old May 5, 2022 | 02:47 PM
Johnny Hardcore's Avatar
Johnny Hardcore
The reset procedure and cleaning the male and female connectors on the seat plug are the easy fix.
Try disconnecting your battery first. Reconnect it, then do the ignition to "on" then reset procedure.
I see I was on yhe thread attached in 2008 and thats when I learned of this. I've had to do it one or two more times since that time. If memory serves...I dont think it works every first attempt. So try the sequence a few times.
Old May 5, 2022 | 02:57 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree that if it works as part of the memory function that it has to be a switch issue. You may have to replace it.
Old May 5, 2022 | 05:37 PM
Moved to C5 Tech for some assistance.
Old May 5, 2022 | 08:14 PM
DJROBJ's Avatar
DJROBJ
My money is on a bad switch. You should be able to find a good used one without breaking the bank.
Old May 5, 2022 | 11:19 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Thanks all. I think it’s the switch as I’ve gone through the “reset” process a few times.
Old May 11, 2022 | 05:59 PM
Johnny Hardcore
Did you disconnect your battery, inspect and clean the blue plug connector under your seat...then try the reset procedure? I would try all of these free steps before digging into the column to replace the switch..
Also, put your "easy entry/exit" on via your DIC. Does the wheel telescope as it should when exiting or when tapping unlock on the FOB prior to entry?
Old May 11, 2022 | 09:18 PM
Johnny Hardcore
Just realizing you have a post about your FOB not working. So easy entry won't work. The easy exit should though. IF your telescoping feature itself is still functional.
Old May 14, 2022 | 04:09 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Just to close the loop, this is fully resolved. After checking the grounds, and replacing a relay, all is operational.
Old Mar 31, 2023 | 08:38 PM
K9Leader's Avatar
K9Leader
I'm having a similar problem on my '99. Telescoping function works both ways, when I hit the memory seat button, it moves out and when I turn the ignition off, it moves back in. But nothing was happening when I tried to adjust it using the switch. I tried the reset procedure and now it seems to work moving out, but not back in. What connections and where did you check/clean and what relay and where did you replace?
Old Apr 1, 2023 | 10:21 AM
grinder11's Avatar
grinder11
Many times a switch goes bad from never being used. Contacts get dirty and corroded, due to never being "scrubbed" by moving the switch. Most C5 owners with memory function have no need to mess with the switch. I've seen the door lock on a couple of cars freeze up from never having the key inserted and turned. Everyone uses the fob, instead.
Old Apr 6, 2023 | 01:57 PM
Justin Raney's Avatar
Justin Raney
What was exactly the problem or why wasn't it working, Thanks
To Electric Steering Won't Come Forward
