Static from instrument panel
Old May 5, 2022 | 12:59 PM
C5admirer's Avatar
C5admirer
Default Static from instrument panel
Help! I have a static type noise coming from the driver’s side inside the instrument panel. Reminds me of a blown speaker type noise, but the speakers are working fine. All of the power accessories are working as they should and it doesn’t seem to be draining the battery. Any body experience this with their 2000 C5? Sometimes the presets don’t work when I first put the key in, if that helps. Thanks all in advance for any advice you can give.
Old May 5, 2022 | 10:06 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
The cluster has a speaker for the chimes. Are you hearing static when the key is in the ignition and door open or if you leave lights on.
Old May 5, 2022 | 10:19 PM
C5admirer's Avatar
C5admirer
Thanks for responding. Noise appears with the door closed, key doesn’t have to be in the ignition. It happens whether it’s in or out, also when the car is running or not.
Interesting that when I got in it after work, it didn’t make the noise and when I put the key in the ignition, my preset seat and steering wheel positions activated like they should.It didn’t this morning when I left for work and the noise continued all of my 20 minute drive. Got out the owners manual and was going to look into pulling a fuse.
Old May 6, 2022 | 01:52 AM
Bandit 00C5's Avatar
Bandit 00C5
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
Had this issue years ago. Here is a link to an old thread that I helped others having the same problem.
https://www.corvetteforum.com/forums...nder-dash.html
Old May 6, 2022 | 02:23 AM
C5admirer's Avatar
C5admirer
Wow! Lots of great info on that thread! Got some investigating to do. Thanks again Bandit 👍
To Static from instrument panel
