Brake question
Old May 5, 2022 | 07:04 PM
UM Rebel's Avatar
UM Rebel
Default Brake question
2004 CE Convertible
I replaced brake pads yesterday. There was no problem. It’s just been a long time and lots of miles. The old pads appeared about 50% worn. Old and new pads are both Wagner Semi Metallic on original stock rotors. I also drained the fluid reservoir and added new. I did not flush the lines or calipers.
Now the pedal is noticeably higher and firmer.
I’m not complaining just wondering why that would be. 🍻
Old May 7, 2022 | 01:23 AM
UM Rebel's Avatar
UM Rebel
Guess that was a boring question. Thought some brake/hydraulic person would try to explain.
Old May 7, 2022 | 12:37 PM
STRMLNE's Avatar
STRMLNE
Probably has something to do with the new pads which are thicker than the old worn pads and when you compressed the pistons, etc. I would do a full bleed though.
Old Jun 9, 2022 | 07:16 PM
bluestreak63's Avatar
bluestreak63
As STRMLNE said, you basically closed the gap that was left by the old pads to the rotor. Emptying and filling the reservoir ain’t gonna do much. You need to bleed the system.
To Brake question
