Drivers side headlight does not open but lights up.
Old May 7, 2022 | 04:51 PM
cloudvette's Avatar
cloudvette
Default Drivers side headlight does not open but lights up.
Drivers headlight does not pop up. It does light up.
Passenger side headlight works like it is supposed to.
How do I fix it. Also, how do I manually pop it up?
Thank you.
Old May 8, 2022 | 03:02 AM
jdmvette's Avatar
jdmvette
Night Owl for life
  • Try spinning the **** on top of the motor to see if it can manually go up and down
Old May 9, 2022 | 11:14 AM
DallasLoneStar's Avatar
DallasLoneStar
This happened to me, and I found a thread where it was recommended to loosen the "for emergency use" **** 1/4 turn or so and try again. That worked for me.
Old May 9, 2022 | 03:09 PM
STRMLNE's Avatar
STRMLNE
that was my suggestion. Haha. Works every time.
Old May 10, 2022 | 10:48 PM
DallasLoneStar
@cloudvette did that work?
Old May 15, 2022 | 03:08 PM
cloudvette's Avatar
cloudvette
Turning the **** couple of turns and then turning on the headlight works. However, it tightens up again and will have to turn everytime to make it work. Should I replace the headlight motor?
Thank you.
Old May 15, 2022 | 05:49 PM
ChristoperCurry's Avatar
ChristoperCurry
6th Gear
Thank you.
don’t turn it a couple of turns. Just turn it one quarter turn counterclockwise. As STRMLNE says, this works everytime.
Old May 18, 2022 | 06:00 PM
UM Rebel's Avatar
UM Rebel
There are a couple of bump stops on each headlight. The stops have a nylon cover. If the cover is damaged or missing headlight door can jam.
To Drivers side headlight does not open but lights up.
