Sway Bar Install
Old May 7, 2022 | 08:56 PM
ssww's Avatar
ssww
Default Sway Bar Install
Good evening everyone. I have a question about a sway bar installation. I am installing Hotchkis sport suspension bars. The back one is non-adjustable (one hole).
My question is, After installing the rear bar, the links (non-adjustable) are not straight up and down. They are angling to the outside. Is this just a matter of rolling the sway bar? Or is this normal?
Thanks for any help. I just got called into work. So it might be a while before I can respond to any replies. So don't think I have forgotten about it. LOL.
Thanks again, Scotty
Old Jun 16, 2022 | 02:54 PM
Pewter0001's Avatar
Pewter0001
2nd Gear
Default Get them installed?
I’m planning on installing mine tomorrow. Did you ever get yours in?
Old Jun 16, 2022 | 03:58 PM
BmoreRnsDeep's Avatar
BmoreRnsDeep
You just want the bar to be able to freely rotate in the bushings and not be preloaded. I used to think you wanted the sway bar arms to be as parallel to the ground as possible but I never have heard of anything on the links.
Old Jun 19, 2022 | 04:48 PM
Autotragic's Avatar
Autotragic
When I installed mine I initially had the swaybar "upside down" or "backwards" and the endlinks were all kinds of misaligned. Once I realized the Hotchkis sticker is supposed to be upside down, it all went together perfectly...If you can read the sticker normally the bar is flipped wrong and nothing lines up.
To Sway Bar Install
