ARP. Bolt for Engine Valve Cover !!!
Old May 9, 2022 | 05:10 PM
link9a's Avatar
link9a
Default ARP. Bolt for Engine Valve Cover !!!
Hi. Do the ARP Bolt 400-7529 Can be work with engine valve cover ?
Old May 10, 2022 | 10:17 AM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
It appears to be compatible, but why? Valve cover bolts aren't any kind of high torque application. It's not really worth spending the money for ARP for something like that unless you need a valve cover bolt and you can get a good deal on the ARP ones. It's not an upgrade of any kind.
Old May 11, 2022 | 06:48 AM
link9a's Avatar
link9a
Thanks. . Yes I understand what you say but any bolt I took off I replace it with the arp if l can ... I don't need to have a headache in the future when I took it out or torque or whatever .
Old May 11, 2022 | 12:51 PM
oharal's Avatar
oharal
I hate to break it to you but ARP bolts are just bolts.
Old May 11, 2022 | 01:09 PM
Napoleon_Tanerite
Noooooo, they're grossly expensive, overrated bolts. I'm not saying they're poor quality, but they're very rarely worth their wild price premium over OEM, especially if you're just doing OEM things like holding a valve cover on.
Old May 11, 2022 | 01:17 PM
helga203's Avatar
helga203
wow to each is own. Well ,i guess if the engine lets go at redline it will stay intact.
Old May 11, 2022 | 01:38 PM
oharal's Avatar
oharal
I'm amused by the idea that a bolted joint application that has RUBBER IN IT would be considered an opportunity for a more expensive fastener.
Old May 20, 2022 | 11:38 AM
BmoreRnsDeep's Avatar
BmoreRnsDeep
They are pretty bolts. I love them personally and would put them in place of every bolt.
Old May 20, 2022 | 10:09 PM
DJROBJ's Avatar
DJROBJ
Being that you won't see these bolts with the intake/coil packs on, and this is not a stressed component of the engine, there is absolutely ZERO reason other than to make ARP richer to buy valve cover bolts from them. Now, head bolts/studs, that's a different topic.
Old May 21, 2022 | 03:49 AM
vette4fl's Avatar
vette4fl
ARP bolts are a great habit. Hell, my bed frame is held together with ARPs!
@link9a Keep up the good work! If you find the arp part number, copy me in. I hope you’re keeping a list of the applications…
Old May 21, 2022 | 08:37 AM
helga203's Avatar
helga203
No, they have the signature name arp. I write on all my bolts arp so i have arp also.
Buddies said that must of been expensive. I said yeah, i went through 2 markers.
Old May 21, 2022 | 07:32 PM
vinco's Avatar
vinco
You must be really excited about ARPs to use 3 exclamation points in your subject line.
Old May 21, 2022 | 08:19 PM
Based on some of the answers, this thread seems to have run its course. Closing it down.
To ARP. Bolt for Engine Valve Cover !!!
