"hot" light
Old May 13, 2022 | 10:14 AM
observer2017's Avatar
observer2017
Default "hot" light
I heard a warning chime and noticed a "hot" label over the temperature gauge and blue glow from the cool side of the gauge and a red glow from the warm side. The temperature gauge itself was normal temperature. Has anyone else seen this?? I can find no reference in any forums. The display faded quickly and no further occurrence. Was it just a dream??
Old May 13, 2022 | 10:24 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I've certainly never heard of the temp gauge lighting up (unless it is part of the entire dash lighting up when the headlights are on). You also shouldn't be getting temp warnings if the gauge is reading normal. You could always pull the codes from the DIC. If it happened, it would have recorded the code. That will give you a good place to start. Good luck.
Old May 13, 2022 | 01:01 PM
Moved to C5 Tech.
Old May 13, 2022 | 01:21 PM
VetteMed's Avatar
VetteMed
I think you imagined it. The stock gauge cluster does not have such capabilities.
To "hot" light
