P1870 code
Old May 19, 2022 | 09:52 PM
ltnate's Avatar
ltnate
Default P1870 code
Got this code. Transmission revved a little in between shifts. Is my newly built trans toast already? Is there anyway to know without tearing the transmission down? Thanks
Old May 20, 2022 | 02:46 PM
mmartinez's Avatar
mmartinez
Harsh 1-2 shift can set this code, I would clear it and hope it doesn't come back, worn valve body in transmission may be the problem, and I don't think there is anyway to diagnose without having to pull tranny.
Old May 20, 2022 | 06:35 PM
ltnate's Avatar
ltnate
Thank you...this is a freshly built motor and transmission. I also swapped in 3.42 gears and a 2800 Converter. I'm hoping it was just a tuning error.
Old May 21, 2022 | 04:33 PM
mmartinez's Avatar
mmartinez
You didn't mention the gear change in your initial post, that will most certainly cause that code, your tunner should be able to disable that code.
Old Today | 08:15 PM
Beast's Avatar
Beast
Whoops, old thread.
To P1870 code
