C-5 Gas gage problem
Old May 20, 2022 | 10:33 PM
Gfulch's Avatar
Gfulch
Default C-5 Gas gage problem
I've seen several threads and used much of the info on C-5 gas gage problems. My C-5 reads empty. I've used the techron (2 tanks) and will use a 3rd soon. I have a fellow vet owner who told me I have to reset the computer and it may work. Can anyone share this procedure? Thanks for any help!
Old May 20, 2022 | 10:51 PM
Corvette#2's Avatar
Corvette#2
Maybe try disconnecting the battery ?
Old May 21, 2022 | 11:08 AM
Moved to C5 Tech.
Old May 21, 2022 | 03:20 PM
mmartinez's Avatar
mmartinez
If the Techron doesn't resolve the problem one of the fuel tank level sending units may have to be replaced. You should have a DTC that will tell you which one is causing the problem.
Old May 22, 2022 | 02:24 PM
grinder11's Avatar
grinder11
Does it ever read anything at all? Mine would slowly go to full, then worked fine until you got down to around 1/2 tank. Then, it stayed at half full until you were almost empty, and then plummet to empty, leaving no warning time until you'd start walking. It took me over 1,200 miles, and 5 bottles, of Techron, before it finally started working correctly. I also used Shell premium, which has Techron blended in with the fuel. Mine never did die completely, as in reading nothing but empty. Best of luck to you....
Old May 22, 2022 | 03:34 PM
Gfulch's Avatar
Gfulch
Thanks for the info! What is a DTC? Diagnostic tool?
Thanks, Gene
Old May 22, 2022 | 03:37 PM
Gfulch's Avatar
Gfulch
Thanks, for the help! No, no reading at all/ I'm on my 2nd tank with Techron. How did you get to half? You just canceled the low fuel alert using the buttons for options etc?
Thanks, Gene
Old May 22, 2022 | 03:39 PM
Gfulch's Avatar
Gfulch
Thanks for the help! I'll try that. What will this affect? Just my set and radio settings?
Thanks Gene
Old May 22, 2022 | 04:33 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
C5 fuel sending units are prone to failure, especially after ~20 years. Techron is just a bandaid shot in the dark that MIGHT work, but just as often will not. The proper fix is to replace the sending units in each fuel tank. If you can identify the offending unit to which tank has failed you can just replace that one, but both of them are prone to fail. If one has failed, the other usually isn't far behind. The job can be a pain in the *** (especially if you have a late 03 or any 04) but it's not insurmountable.
Old May 23, 2022 | 10:00 AM
grinder11's Avatar
grinder11
Thanks, Gene
DTC is Diagnostic Trouble Code......
Old May 23, 2022 | 10:03 AM
grinder11's Avatar
grinder11
Thanks, Gene
After it finally read full, it went normally to half, as the fuel was used. But it wouldn't read below 1/2 until there was-MAYBE-1 gallon was left!!!
Old May 23, 2022 | 10:21 AM
helga203's Avatar
helga203
DTC 0463 0462 are the codes. this is what i had, hade to change both.
Old May 23, 2022 | 08:02 PM
Gfulch's Avatar
Gfulch
wow! Problematic! Thanks for the help!
Old May 23, 2022 | 08:03 PM
Gfulch's Avatar
Gfulch
Thanks so much! I'll check it out! Gene
To C-5 Gas gage problem
