Clean C5 rear diff Magnet?
Old May 25, 2022 | 08:44 PM
Chucklehead2's Avatar
Chucklehead2
Default Clean C5 rear diff Magnet?
So Im about to do a rear differential fluid job. Id like to get inside the cover and clean off the magnet and just have a quick peak inside. I’ve searched and cant seem to find squat on this. Mostly was trying to find a seal part number- my assumption is there’s a gasket or some other seal that would need replaced if the cover is removed.
OR is this a jack in the box and ****’s gonna start flyin out when cover comes off- like a spring or something… I don’t think so but don’t know what I don’t know.
thanks for ANY help / guidance on this!
Old May 26, 2022 | 07:03 AM
VetteMed's Avatar
VetteMed
No jack in the box effect, removal of the cover just gives you a look at things without anything falling out (unless something is broken to begin with!).
Gasket, r/axl hsg cvr(1st design has viton o-ring, for 2nd design w/edge bonded gasket see 89060114) Y 6.0-U(LS2),6-SPD M/TRANS(MZ6),1ST TO 4TH GEAR SKIP SHIFT CONTROL(JL5),HVY DUTY TRANS CLG SYS(KNP),(1ST DES) 01 89047954
Old May 26, 2022 | 08:24 AM
Chucklehead2
Thank you - since mine is with an automatic transmission i think you are saying that I need gasket GM part number 89060114. Yes?
Old May 26, 2022 | 08:30 AM
VetteMed's Avatar
VetteMed
Possibly. That PN is a reusable viton o ring, but if that's what's on yours, it should be reusable. Really just need to take it apart and see.
To Clean C5 rear diff Magnet?
