NEW VETTE! ABS/Traction Light On Dash
Old May 30, 2022 | 11:14 AM
bnreed3's Avatar
bnreed3
Default NEW VETTE! ABS/Traction Light On Dash
Hey everyone, been awhile since I have been on here. Sold my 99 FRC six years ago and just snagged a 2003 Corvette in canary yellow for a great price. One of the issues I have - two lights on on the dash (ABS/Traction). I did some research in the forums and there seems to be many different things this could be attributed to. I was just curious if you guys have a list of what to try first (going from the easiest of fixes to more difficult). I can get my hands dirty but I am by no means a mechanic - I am trying to keep it out of the shop.
I've heard a low battery can cause issues so I did hook up a charger yesterday and sure enough it was below 10%. Did not fix any lights on the dash.
Here are the codes I took off of the diagnostic:
A6-SCM B2860 H (looks to be memory seat position issue, so no big deal)
58-SDM U1040 H C
10-PCM P1571 H C
99-HVAC B0441 H (there is no AC in the car, so I probably just need to recharge the AC system)
99-HVAC B0361 H (" " ")
Old May 30, 2022 | 12:54 PM
Dudly Doright's Avatar
Dudly Doright
I get this one on my 98 fairly often, Has been attributed too loose, dirty or disconnected wiring each time in the rear end at the rear Hubs each time so far.
How the Plug comes disconnected on its own I have no idea as the safety clip seams to lock fine to me.
Old May 30, 2022 | 03:03 PM
bnreed3's Avatar
bnreed3
Well, I will start there.
Old May 30, 2022 | 03:17 PM
Speedy007's Avatar
Speedy007
I had that twice once from the wire under there center console was rubbing, second I had a vara air tuberlator plastic piece that was hitting the throttle body . Could be maybe the module is done
Old May 30, 2022 | 10:44 PM
bnreed3's Avatar
bnreed3
How do you even diagnose it to those certain points? I mean, there are so many different things that factor in to a certain code. How would you even know to look under your center console?
Old May 30, 2022 | 11:24 PM
Speedy007's Avatar
Speedy007
I start from common sense and work my way towards the wtf ….
Old May 30, 2022 | 11:32 PM
Dudly Doright
Bnreed3
I seriously have found my wiring to my Hubs bad causing this problem Speedy007 is directing you to the EBCM modual right off the bat without any trouble shooting.
This is a very expensive module to to have repaired or replaced,
Their are however many videos and online web forums with repairs for it listed on this web sight as well as others and U tube as well their is also an online web sight that offers repair service for it if needed.
I simply offered real world experience with the problem and NOT the "Your module is bad repair or replace it" Nor did I give a Smart *** reply! This web sight is bad about accepting smart asses that offer no real world experience repairing stuff they just Parrot what they have heard or read OR PAID for writing checks or using Credit cards.
The Corvette world is FULL of these types no matter were you go very few actually know how to fix anything themselves they always break out the check book or the plastic.
With all problems trouble shooting needs to be done first! eliminate the easy cheap stuff first and go from their. good luck my friend.
Old May 30, 2022 | 11:35 PM
Speedy007's Avatar
Speedy007
No there is a traction control button I am referring to on the arm rest center console the wires under it can rub out and cause a open short it’s as simple as removing 4 10mm nuts and inspection with a light … slap it back on neatly if it’s all appears good ..
By the way Dudley the ecbm is located under the passenger foot well and no one mentioned that in any post please get your geography right. People don’t know the difference bxt a traction control module and a electronic body control module these days ..
Hence he could have a bad abs sensor or abs module .. it’s all about starting from easiest to hardest. There’s also a sensor on the trans that could also be the culprit .
Personally I would check the center console wires 1st . Clean the maf and tb out just to ensure it’s not sticking … Fire it it up .. then move on to a proper diagnostic shop if I couldn’t find what’s happening.. and go to the dealer
Hey if it so happens the trac control is bad that part is so easy to change out and will cost ya maybe 25 bucks at a scrap yard
As for your a/c issue probably just change the valves there what 2 bucks
Anyways to sum the issue on what your looking for on the pcm code is a open circuit that’s either a bad module or open wire there’s not in between good luck of ya need help we are here
Old May 31, 2022 | 08:20 AM
Dudly Doright
Good post!
Old Jun 2, 2022 | 04:37 PM
Mike_Long's Avatar
Mike_Long
2nd Gear
Default Traction Control / ABS
Not sure if this is the best place to start but I'll give it a try.
I have a 1998 C5 Vert that is giving me the traction control / abs warning. The car has 43,000 on it, sat for ± 6 years, the code is C1232, no others, what is odd to me is that I can drive the car for an indefinite time under 35 MPH and then as soon as I go over 35 the warning pops up, I have skid tested and the ABS appears to be working even though the light is on. If I shutdown and restart the code is gone and I get code H1232. What I've done so far is clean up the mess from a leaking battery, cleaned the wiring harness and checked all of the connectors on the computers, there was no corrosion to any of the wiring or connectors. I replaced the connector harness to the wheel speed sensor, cleaned all of the grounds on the chassis, disassembled the ground packs and cleaned them. I tested the voltage coming from the wheel speed sensor, it appears to be in normal range. Other than this issue this car is very clean, I'm hoping it's not the ecbm! Any help is appreciated.
Mike
Old Jun 4, 2022 | 04:42 PM
bnreed3's Avatar
bnreed3
Hey guys,
Thanks for the info! I did find out my battery was shot so I bought a new one and some of the codes did go away; however, the main ones stayed. Here is the new list of codes I have...
10-PCM P1571 HC
28-TCS No Comm
58-SDM U1040 HC
A1-RDCM B2265 H
A6-SCM B2860 H
To NEW VETTE! ABS/Traction Light On Dash
