C5 OEM Brake Duct Installation
Old May 30, 2022 | 02:19 PM
blackvette58's Avatar
blackvette58
Default C5 OEM Brake Duct Installation
What is the correct process for installing OEM brake ducts (C5). Mine came without them and have just purchased them. Searched various sites but did not find anything in this regard. Thanks.
Old Jun 2, 2022 | 08:47 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Assuming that you mean the rear brake ducts, I suggest that you do a "search", as the installation process was well documented on this forum, back when our C-5s were newer, and a number of owners were adding these Z-06 ducts to their cars.
Old Jun 4, 2022 | 09:04 AM
blackvette58
Actually, I was referring to the front factory cooling ducts for the standard C5 (2002). I pulled the lower panel off, which accesses the parking lamp unit, but in order to fit the duct in the panel above it, more needs to be done to mount it. The upper panel has a circular hole with two indentations through which the duct is inserted and locked into place. There is not enough space to fit the duct through this hole unless the panel is removed or flexibly adjusted (bendable?) by just removing the two bolts holding it to the fender-well. Or, if the interior side of this panel, which appears to be "bonded" in place has to be disassembled, a much bigger job, is required for installation. When I purchased the car the cooling ducts were not present. I do not need them for functionality as I just drive the car minimally and gently. However, I thought for "stock" purposes, i would install them. But, at the same time, do not want to get into major panel removal and replacement. Suggestions would be helpful. Thanks.
To C5 OEM Brake Duct Installation
