plz help air selonoid
Old Jun 2, 2022 | 06:59 PM
Chazo Stankovic's Avatar
Chazo Stankovic
Default plz help air selonoid
I had my vacuum lines eaten away at my air selonoid for the smog pump.. I have no idea which side on the selonoid the vacuum line with vacuum goes in, it also seems it's low on vacuum, on my gauge it's not in the green it sits midway, is that normal, I purchased a new selonoid online but I think I hooked it up backwards plus I mounted the new selonoid to close to the motor when I try to activate it with a scan tool no vacuum passes thru it either way, maybe from the engine heat it broke, can any1 give me some guidance, keep getting that darn p0410 code, been driving me crazy, can't believe the new one broke, already.. I've been searching for a non existing vacuum leak(I think). can't pass inspection, been struggling with this for a while, any1 with a picture that details which side the vacuum goes in wud help me greatly
Old Jun 2, 2022 | 07:24 PM
Chazo Stankovic
the vacuum line going to the selonoid has half the vacuum than the vacuum line off the brake booster, at the booster everything is fine it sits in the green
