Link Kit,Rear Suspension Inner Toe
So I'm looking for 2 inner tie rods, also called :
GM 26058599
Link Kit,Rear Suspension Inner ToeIt appears this part fits both C5 and C6 cars but has been discontinued by GM. I haven't found aftermarket replacements either.
Any suggestions?
Anyways, for outers at least I went with Ecklers and they should be arriving today: https://www.ecklerscorvette.com/1997...-112910-1.html
For inners, the only current options I came across are performance versions:
https://www.lgmotorsports.com/lg-mot...steer-kit.html
https://www.ebay.com/itm/303669754538
https://www.topflightautomotive.com/...ump-steer-kit/
I don't know if the C6 rear inner tie rod is compatible with the C5, but I came across this:
https://www.partsgeek.com/sdrsytm-ch...e-rod-end.html
Also I did even further research. Have no idea if Suspensia parts are any good, but I did a search on their website for C5 rear inner tie rod: https://www.suspensia.com/product-catalog.html
Came up with P/N X07TR1211, which I've only found on Rock Auto: https://www.rockauto.com/en/moreinfo...t=7428&jsn=920
It cross-references with GM # 88955489, which appears to be for the rear inner tie rod.
Heck, maybe I should order a couple just to have them on-hand...
Thanks for the reply. I found out that the GM part is NOT discontinued. For some reason the GM online dealer show it as discontinued, but it is actually available at the dealers. Maybe a parts file snafu.
The ones from Rock Auto are pretty cheap at $21.79. The Dealer MSRP is $103 for the GM part. Looks like I can get them for $70 from a GM dealer if I shop around. I'm not sure if I should go for OEM or try the cheaper parts.
Dave
