2003 c5 timing chain history
Old Jun 6, 2022 | 05:43 PM
MikeInMelbourne's Avatar
MikeInMelbourne
Default 2003 c5 timing chain history
Hello....Hopefully I can get a few replies that shed light on '03 timing chain life. Yep..I know some go at 50K...some north of 200K. The variables are many ie service and abuse/abuse.
I still assume there's an average or typical that the reader of this post may have feedback on and will pass it along. Thank you for reading...Mike
Old Jun 8, 2022 | 05:50 PM
mmartinez's Avatar
mmartinez
Timing chain life time is dependent on how the car has been driven, my opinion is to change it once it goes over 150k, best to change instead of having it skip a few teeth and ruining the engine.
Old Jun 8, 2022 | 07:20 PM
Chucklehead2's Avatar
Chucklehead2
Is there a good DIY guide in this by chance somebody can share.
For some reason searching information on this site just does not work well for me- I get better much better results search in my browser and seeing the forum as the site with the topic…
Old Jun 9, 2022 | 11:06 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Actually, if you research "LS harmonic balancer removal/replacement", that will cover a good portion of the work involved. Once the balancer is off, it's just a matter of removing the front cover of the engine, and accessing the timing set. Replacing the timing set isn't the hard part, it's all the disassembly that you have to do, in order to get to it.
Old Jun 9, 2022 | 02:54 PM
vette4fl's Avatar
vette4fl
Including removing the oil pump…. Since removing pump anyway, there’s a perfect “while you’re in there” opportunity. A high volume pump keeps the oil available off idle, but also comes fitted with the higher pressure relief spring (the standard spring is included with the pump as an option). The higher pressure really comes into play at higher rpm, where the OEM would start to open the relief valve. In other words it takes up the slack of the OEM pump at the very low and very high ranges. Win-win!
Old Jun 10, 2022 | 08:14 AM
leadfoot4's Avatar
leadfoot4
Yeah, that too! It's been a while since I've been that far into my 'Vette's engine............
To 2003 c5 timing chain history
