Hyper flashing 4 ways
Old Jun 6, 2022 | 06:39 PM
glbeauchamp's Avatar
glbeauchamp
Default Hyper flashing 4 ways
I replaced all the bulbs with LEDs and installed the hyper flash harness. The brake and turn signals function normally, but the emergency flashers now hyper flash when when activated. Is this normal? If not, what' is wrong and can it be rectified? Thanks for the help
Old Jun 6, 2022 | 08:44 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Strobing emergency flashers may actually be a benefit
Old Jun 6, 2022 | 09:37 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
It depends on the lights. With the new Gen 2 Vette-Lights LED tail lights I just installed, it does the hyperflashing. With the Gen 1 lights it didn't. There's a resitor on the Gen 1 that the Gen 2 doesn't have. I have an older hyperflash harness installed but that really shouldn't matter. I think it depends on what lights you have.
Old Jun 6, 2022 | 10:49 PM
glbeauchamp
For as often as I use the hazard flashers, I'm thinking of just leaving them the way they are
Old Jun 7, 2022 | 10:05 AM
mstromquist
Yep, that's my plan too. Won't hurt anything.
Old Jun 7, 2022 | 12:11 PM
Moved to C5 Tech.
Old Jun 7, 2022 | 09:56 PM
Ed Ramberger's Avatar
Ed Ramberger
Normal because the 4 ways use the flasher in the hazard switch. I installed halo tail lights with resistors. I hate resistors in lighting circuits (just draw current and make heat) so I removed them. I have normal blinkers due to the hyper-flash harness and fast hazards now. I am fine with it - how many times do you ever really use hazards and when you do they will definitely be seen now.
Old Jun 14, 2022 | 10:17 AM
servohead's Avatar
servohead
Weirdly I just replaced my hazard switch due to inoperative directionals at times. Now I have the directionals hyper flashing but the 4 ways flash normal speed. No bulbs are out.... Did they change something with the Hazard switches? I bought it from corvette central.
- Steve
Old Jun 10, 2023 | 05:34 AM
link9a's Avatar
link9a
- Steve
Are your rear taillight led ? If yes do they have resistor ?
To Hyper flashing 4 ways
