Heads up display
Old Jun 7, 2022 | 09:50 PM
2004specialc5's Avatar
2004specialc5
5th Gear
Default Heads up display
Just bought a c-5 noticed that the heads up not working where do I start trouble shooting
Old Jun 7, 2022 | 10:08 PM
1911tex's Avatar
1911tex
Maybe the panel screen is dirty, Maybe the location on the windshield is too low and needs to be raised, Maybe the dimmer is too dim?
Old Jun 7, 2022 | 10:31 PM
Alley Oop's Avatar
Alley Oop
Go to youtube and check out... HTH
Broken C5 Corvette HUD- Two Common Repairs
Old Jun 8, 2022 | 07:28 AM
vinco's Avatar
vinco
Start by turning the ignition on when it's dark at night and looking down into the unit through the windshield. If you can see the blue-green glow, then the support pin/bushing has likely failed. Cheap fix if so, but you have to pull the dash out to do it.
Old Jun 8, 2022 | 10:38 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
It's a common issue. I had it happen to mine. The repair has held up for years now.
Old Jun 8, 2022 | 11:58 AM
1stC5vette's Avatar
1stC5vette
Plenty of guides out there and after watching you'll see its a real pain to get to in order to fix it.
However, I purchased mine with the HUD broken too. Now that I went in and fixed it I really wish I would've done it sooner its awesome. Definitely worth the hassle.
Old Jun 8, 2022 | 02:28 PM
MWWarlord's Avatar
MWWarlord
Yeah, the HUD is awesome. I wish I had one in my SUV as well. Once you have one, it will spoil you forever.
Old Jun 8, 2022 | 05:57 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Don't feel too bad. I took my dash apart to find my car was not wired for the HUD.I want my 6 hrs back. lol
Old Jun 9, 2022 | 03:49 PM
Moved to C5 Tech.
Old Jun 10, 2022 | 07:32 PM
grinder11's Avatar
grinder11
This sounds like the guy who drained his trans fluid, then couldn't find the fill port!!!
Old Oct 3, 2022 | 07:25 PM
bearone2's Avatar
bearone2
did every c5 after '99 have hud or an option?
Old Oct 4, 2022 | 11:47 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
That's what's wrong with mine. It gets done on Monday. I was quoted 4 hours for the repair by a buddy that repairs Corvettes. He's also fixing my dim HVAC and some burned out bulbs in it.
Old Oct 6, 2022 | 01:39 PM
RPGR90s's Avatar
RPGR90s
First thing first. Use the Up/Down switch to change it's position on the windshield. My wife drove mine recently and had adjusted the HUD. I got in and couldn't see it and immediately thought it had failed.
I just had to adjust it to my viewing angle.
Old Oct 11, 2022 | 05:42 PM
corvettezman
$400 later, I have my HUD back and my HVAC brightness restored. It took less than a day for the repair.
Old Oct 11, 2022 | 06:29 PM
bearone2's Avatar
bearone2
what did you have to send in for the repair??
Old Oct 11, 2022 | 08:14 PM
corvettezman
The whole car. The gentleman is local to me.
I dropped it off, he took the dash out , put new pins in the HUD and re-aligned it. then put everything back together.
He also took apart my HVAC display and re-soldered the chips.
I went back the next day and picked the car up. All nice and neat.
Old Oct 11, 2022 | 08:50 PM
bearone2's Avatar
bearone2
thank you!
To Heads up display
