01 Vette fuel gauge reading erratic
Old Jun 8, 2022 | 04:27 PM
mickeysenior's Avatar
mickeysenior
1st Gear
Default 01 Vette fuel gauge reading erratic
Our 01 Vette at time reads low when apparently below about 1/2 full. I hav
e had the computer
er flashed at dealer and it was good for a while. Now
thinking ma
ybe
one of the fuel modules is culprit. Anyone
know of a way to determine which affects the gauge or do I take a chance on one or the other
Old Jun 8, 2022 | 04:36 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Try here.. Welcome
Old Jun 8, 2022 | 05:43 PM
mmartinez's Avatar
mmartinez
By modules you mean the fuel level sending units? The c5 has two tanks the fuel level sending units each send a voltage to the pcm which then sends the appropriate voltage to the fuel gauge. I would try two treatments of Techron complete fuel system cleaner, it should resolve the problem.
Old Jun 8, 2022 | 08:07 PM
kkupec02's Avatar
kkupec02
Welcome.
Old Jun 9, 2022 | 11:09 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
In MANY cases, running a bottle or two of Techron fuel additive through the fuel system, cleans off the built-up oxidation on the fuel gauge contacts, which are within the tank. It's the easiest, cheapest thing to try first.
Old Jun 9, 2022 | 12:02 PM
grinder11's Avatar
grinder11
TECHRON to the rescue.....most times! It worked for me. The key thing is to not give up on it too soon!! I almost did!! It took me 6 bottles, and driving to Florida from Michigan. Used a couple bottles just before leaving, then every fillup driving to Florida. About the time I hit the Georgia/Florida border, it started reading pretty decent. By the time I reached my destination, it was fine, but it took a few fillups before I really trusted it again. The gauge has worked perfectly ever since. Sometimes it doesn't work for everyone. I do suspect many may try a bottle or two, and give up. I almost did......
Old Jun 10, 2022 | 12:42 PM
Rumplemenzz's Avatar
Rumplemenzz
TECHRON! as others said... worked for me
Old Jun 12, 2022 | 08:47 AM
NjC5Vette's Avatar
NjC5Vette
I have a similar issue, used one bottle and it helped a bit.
Can I use 2 bottles at once or use one, drive until low, then use another one on the next fill up?
Old Jun 15, 2022 | 04:38 PM
spfautsch's Avatar
spfautsch
I've never been a big believer in any kind of liquid additives. But this stuff actually made a difference for me. Best to buy a couple liters and use it all before replacing parts. 1oz per gallon.
Amazon Amazon
I haven't used any in a while. Before running a couple liters through mine, the gauge would never go above 7/8ths.
Now it seems like my passenger side sending unit will read zero (empty) when below 1/2 of a tank. Not a huge problem since that tank will actually be mostly empty after the car's been running for a while. I noticed this when the gauge would go up from just above 1/4 to 1/2 after driving for a while.
Not that it's a fixable problem - the word I've heard is that the sending unit for the passenger side tank has become unobtanium.
Old Jun 16, 2022 | 08:24 AM
leadfoot4's Avatar
leadfoot4
It's been a week, with no follow up. I wonder what the OP did (or didn't do.....)
To 01 Vette fuel gauge reading erratic
