99 AC typical questions
Old Jun 10, 2022 | 07:13 PM
67air's Avatar
67air
Default 99 AC typical questions
Hey guys ,
I found a 99 ( original owner 45K miles) last Fall and it is 100% stock. ( Exhaust too quiet but not my issue now.)
She has the typical c5 issues, no display for climate control but I fixed that this week with 2 hrs of labor and soldering.
SO my question to you guys is that she had no cold AC and I charged her but that lasted all of 24 hours.
Upon research, its a case of the typical split AC case gasket ( we used a sniffer tool) so I need to replace the compressor or the large O ring.
Im a usual C2 **** original guy so what can you guys recommend; remove and replace the original water pump and compressor or remove and have them rebuilt by a fair reputable shop.with my original parts ? I can turn a wrench, so Im not shy about the work involved.
I'm in no hurry, but Im enjoying her alot ( with the exception of 1st gear ) and I want to have reliable AC on trips with the Wife ?
THESE c5s with their LS engine are a hidden gem like the C2S with the 327/350 Motors.
if possible, I'd like to retain ALL her original parts.
I think its smart to do the water pump rebuild as well as fix my leaking AC compressor!
So what can you C5 guys advise me to do ?
Thanks in advance, Fred
Old Jun 11, 2022 | 06:56 PM
bookyoh's Avatar
bookyoh
Just curious, why the interest in rebuild versus new?
The compressor is a big job to replace. The body o-rings, shaft seal, seal washers, o-rings for the control valve, and o-ring for the high pressure relief valve can all be replaced if everything is good mechanically with your compressor. There is a small risk of a leak when you retorque the 4 through bolts that hold the compressor together.
I would not take a chance on going through all that for a C5 to save some dollars. Something like an S10 where it us easy to replace, sure, why not rebuild. A new Delphi replacement is less than $300.
Old Jun 11, 2022 | 09:39 PM
67air's Avatar
67air
Understood ,I realize it's no small job, water pump etc but that why I asked about rebuilding vs a replacement. 75% of the replacement parts are Chinese JUNK and I'd rather just keep her 100% USA made parts. Something about Chinese parts on ANY CORVETTE makes me sick. Not an option for me personally. Thats why I wanted the opinion & options of you guys-------
Old Jun 11, 2022 | 09:59 PM
ThomasR's Avatar
ThomasR
I just bought a brand new genuine GM A/C compressor from Rock Auto for $316. I have the same problem as you and I plan on saving and resealing my old compressor as a backup. It still works great it just leaks.
Old Jun 11, 2022 | 10:44 PM
67air's Avatar
67air
Thats exactly what my comp is doing Robert. I charged her up and it came out ice cold the next day----nothing. My pal has one of the freon detecting wands and she leaks bad . Are you planning to rebuild or replace your original water pump Robert?
Old Jun 11, 2022 | 10:46 PM
67air's Avatar
67air
My apologies-------THOMAS.! Sorry
Old Jun 12, 2022 | 02:42 AM
ThomasR's Avatar
ThomasR
I'm going to reuse the water pump.
Old Jun 12, 2022 | 08:52 AM
67air's Avatar
67air
Ok , well I figured since my car is 23YO with 45k miles it would make sense to replace and or rebuild mine. First the fun part of getting it all apart . Ill check out compressor suppliers like RA later.
Old Jun 12, 2022 | 11:11 AM
bookyoh's Avatar
bookyoh
I understand the desire to keep stock parts but don’t have high expectations to see USA on your compressor. The OEM compressor was manufactured in Korea by a GM (Harrison Radiator)/Daewoo joint venture. I expect that same plant is making the DELPHI service compressor today.
Old Jun 12, 2022 | 02:25 PM
67air's Avatar
67air
Geez thats depressing,KOREA but am I surprised NO !
Thanks for your 2 cents ----Im going to look around on rock auto and flea bay I think.
Old Jun 12, 2022 | 09:58 PM
bookyoh's Avatar
bookyoh
Well, if it helps you feel any better, many of the components were made in the US and shipped to our Korean joint venture for assembly. The Corvette V7 compressor was low volume so it went to the joint venture to manud@cture. The high volume models were made in Moraine Ohio.
There may be good aftermarket copies of the V7 but I would stick with the Delphi OEM. Last I checked they were under $300 on Amazon.
Old Jun 13, 2022 | 10:08 AM
67air's Avatar
67air
Thanks Bookyoh. Appreciate that. I did notice yesterday that rock auto had AC Delco replacement compressors, but you are partial to the Delphi 's ?
Old Jun 13, 2022 | 10:10 PM
bookyoh's Avatar
bookyoh
I would think they are the same compressor. Hard to imagine A/C Delco buying a non OEM compressor as a service model from someone else
To 99 AC typical questions
