Cranking compression....
Old Jan 3, 2003 | 01:14 PM
Phil97SVT's Avatar
Phil97SVT
Default Cranking compression....
Anyone ever check cranking compression after installing a set of high compression heads and cam? What were the pressures?
Phillip
Old Jan 3, 2003 | 08:36 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Cranking compression.... (Phil97SVT)
I've tested several cars.. they tend to run 155-165 on stock bottom end vette's.. My stroker, which runs quite a bit higher compression, is in the 190-200 range..
Old Jan 4, 2003 | 12:37 PM
SFVetteman's Avatar
SFVetteman
While raising the compression ratio with the heads increases the compression pressure, the more radical the cam the lower the compression pressure. Since you have a 110 LSA, I would think that it has a significant amount of overlap and the more overlap the less compression pressure.
I think the key thing to look for is that the compression pressure is pretty much even cylinder to cylinder.
Old Jan 4, 2003 | 01:45 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Cranking compression.... (SFVetteman)
Won't his intake centerline also effect his crank comp, ie straight up ,advanced or retarded?? :cool: :cheers: :steering:
To Cranking compression....
