Line Lock and adapters...
Jan 3, 2003 | 01:57 PM
Which line lock should I buy and what lines/adapters do I need?
Phillip
Jan 3, 2003 | 02:50 PM
Re: Line Lock and adapters... (Phil97SVT)
http://forums.corvetteforum.com/zerothread?id=390641
pictures are down right now, but I have the part number listed for the adapter to go from our metric lines to 3/16 standard.
Eric
Jan 3, 2003 | 03:00 PM
Re: Line Lock and adapters... (66ImpalaLT1)
So in summary:
Line Lock
Line Lock install kit with 3/16" lines
12mm to 3/16" adapters(2)
Phillip
Jan 3, 2003 | 03:03 PM
Thats what I used.
I also built a small bracket to hold it to the front stud of the washer fluid reservoir.
This approach also leaves you with the stock proportioning valve to abs line so you can revert back if you ever wanted to.
Eric
Jan 3, 2003 | 11:33 PM
I recently ordered one from Cartek - have not installed it yet. It is supposed to come with all the fittings lines for use with C5s and with active handling.
Jan 4, 2003 | 01:28 AM
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Line Lock and adapters... (SilverStateZ06)
Phil..I used the 3/16 line from the distribution block to the Line lock and then a flex line form the Line lock to the ABS module. I'll see if I can dig up some pics.
Found one..................
[Modified by Mag Red Monster, 1:31 AM 1/4/2003]
Jan 4, 2003 | 01:43 AM
Elite Member
Been having trouble getting this one to display......................
Jan 6, 2003 | 07:04 PM
Elite Member
Re: Line Lock and adapters... (Mag Red Monster)
So Phil.........what's the progress?????????? Did you get it installed?????
Jan 6, 2003 | 08:07 PM
Thats my next mod...working on it....like always I will post pics.
Phillip
