Harmonic Balancer
Old Jun 17, 2022 | 08:02 PM
fkhachi's Avatar
fkhachi
3rd Gear
Default Harmonic Balancer
Hello
Thank you so much for allowing me to join and post.
I recently purchased a new 2003 C5 with 28K miles. I would like to know more about Harmonic Balancer and when I should replace.
I have made 2 videos on my YouTube channel providing more information on the Harmonic Balancer while engine is running and off.
Links;
Questions;
1. Looking at the videos, should I change it right away or I still have time?
2. I do work on my cars in my garage. Don't have a lift. However, I was wondering if this is a job I can tackle myself or should I have a pro to take care of?
I live in Los Angeles - San Fernando Valley area and would love to know of a good Corvette mechanic shop that I can trust to do the work. Any recommendations would be greatly apricated
3. What parts or model numbers do I need to replace while doing this job and where should I be purchasing these parts from?
Thank you so much
Old Jun 18, 2022 | 08:53 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You balancer is fine. The running video shows normal operation.
Pro tip; take some white touch up paint and "draw" a single line from the inside of the balancer (the rubber part) to the outside of the metal. You keep and eye on this. If the line stay in place, you have no problem but if they split apart, it means that the rubber has separated from the balancer and started to spin, hence needed to replace the unit.
Old Jun 18, 2022 | 09:59 AM
UM Rebel's Avatar
UM Rebel
Hi, welcome! Your. Balancer looks and sounds perfect. I wouldn’t mess with it. 28k miles. It’s barely broken in. Drive it and enjoy.
Old Jun 18, 2022 | 10:45 AM
UM Rebel's Avatar
UM Rebel
Here is video of my 2004 with 133k miles
File Type: mov
Old Jun 19, 2022 | 06:42 AM
Moved to C5 Tech.
Old Jun 19, 2022 | 01:58 PM
rrwirsi's Avatar
rrwirsi
My 04 C5 Vert HB tanked at 32K. Just keep a watchful eye on it every time you open the hood to see if there is a wobble. If yes, replace.
Old Jun 20, 2022 | 12:29 PM
fkhachi's Avatar
fkhachi
3rd Gear
Thank you so much everyone for your time and your pro suggestion. have a great day. Franklin
To Harmonic Balancer
