Aftermarket speaker !!
Old Jun 19, 2022 | 10:47 AM
link9a's Avatar
link9a
Default Aftermarket speaker !!
Hi .. ...l need to make sure about those speaker size for convertible model
Front doors. Are
JBL GX Series 2-way JBL GX302 (3½")
Rear ..
JBL GX Series 2-way JBL GX502 (5¼")
Is that right ?
I noticed the problem is the rear GX502 Not available so what ldo ? Do I can go different brand from the front to the rear ? .. I have double din stereo l just need to replace the speakers any help ?
Old Jun 19, 2022 | 12:56 PM
jdewolf's Avatar
jdewolf
The fronts can fit 6 1/2 easily, unless you're planning on keeping the factory door woofers?
Old Jun 19, 2022 | 01:14 PM
Autotragic's Avatar
Autotragic
Front doors. Are
Rear ..
Is that right ?
If you like JBL then check out Infinity. Same brand but the Infinities have a slightly better sensitivity rating and slightly less impedance as I recall. I used Infinities and they fit perfect as well. Make sure to get bass blockers for your front speakers so you can finally get some bass from those 8in subs in the doors.
Old Jun 19, 2022 | 01:39 PM
link9a's Avatar
link9a
I forgot to say guys are the OEM amplifier have 4 ohm ? Which mean the total for all 4 speakers they should be 4 ohm to protect the amplifier from destroyed ? How much ohm each speaker it should be ?
l just need to change Only the speakers but in same time ldon't want to destroy the amplifier ?
lam not going to change the woofers ...
I don't care if Different brand speaker
Old Jun 19, 2022 | 04:28 PM
Autotragic's Avatar
Autotragic
The factory amps will only power the door subs, your headunit will be powering the 4 main speakers. Any automptive speaker in the 4 ohm range will work. I think my Infinities are like 3.5 ohm or something. It's fine. The impedance of a speaker isn't static, it's actually dynamic and there is a whole lot of science involved that isn't worth going into here but suffice to say any general automotive speaker will be fine.
Old Jun 19, 2022 | 04:46 PM
link9a's Avatar
link9a
thanks for the answer . Do you have part number for the front and for the rear (Infinities ) that we'll make it easy for me ? And about the bass blockers do l need to go with 600hz front and 300hz rear ?
Old Jun 19, 2022 | 09:16 PM
Autotragic's Avatar
Autotragic
I did 600hz for the fronts and 150hz for the rear, not sure it was needed for the rears but that's what I did.
Infinity Reference REF-3032cfx up front and Infinity Reference 5032CFX is what you'd want for the rear. Those look like they are discontinued by Infinity but they are still available for now.
Old Jun 19, 2022 | 09:22 PM
link9a's Avatar
link9a
thank you 👍
Old Jun 20, 2022 | 06:31 PM
link9a's Avatar
link9a
I spoke with Crutchfield technical support they say you need 150 bass blockers for the smaller speaker but the bigger speaker you don't need ... . question are the front speaker they need some work with the wires ( cut , soldering) or no ?
To Aftermarket speaker !!
