AC Not Blowing Cold Air - Codes
Old Jun 29, 2022 | 02:48 PM
magneticredc5's Avatar
magneticredc5
Default AC Not Blowing Cold Air - Codes
So I have an issue with my AC, one day it was working fine and the next, all of the sudden it was blowing hot out of both driver and passenger vents. I took the car to a shop, and the told me that it brought up the following codes: B0361, B0367, and B0441. I'm thinking it's a blendoor actuator issue, but I'm not sure which one. Any way to tell? Any suggestions on what to do would be much appreciated. I have a 2004 C5 with the auto climate control option for the driver's side. I can hear a slight clicking noise when I engage the A/C, but it's very hard to hear due to my loud exhaust - and the A/C won't come on unless the engine is running - not sure if this is another glitch. Thanks in advance!
Old Jun 29, 2022 | 10:19 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Did they check your AC charge? If the charge is fine and you are getting those codes, I would replace both actuators; they all fail eventually if they haven't been changed.
Old Jul 3, 2022 | 10:56 AM
huesmann's Avatar
huesmann
Not a glitch—A/C won't come on if the engine isn't running. Our cars don't have electric compressors. If the engine isn't rotating, the A/C compressor isn't rotating, and you don't get A/C.
Old Jul 5, 2022 | 05:05 PM
JordonPoole's Avatar
JordonPoole
Most likely, you have several issues. Blend door codes can't be ignored. You need to replace those. Second, charge the system with extra dye. Check again later for leaks.
To AC Not Blowing Cold Air - Codes
