Front end alognment spec
Old Jan 4, 2003 | 04:08 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Front end alignment spec
What is the best spec for an front end alignment for all around handling on the street?
[Modified by Caveboy, 1:09 AM 1/4/2003]
[Modified by Caveboy, 1:10 AM 1/4/2003]
Old Jan 4, 2003 | 01:17 PM
carpe dm's Avatar
carpe dm
Default Re: Front end alignment spec (Caveboy)
The stock GM specs are OK for the street with the exception, IMHO, of the spec for camber. For "street" driving, I think you want to get as close to "0" camber as possible. (Maybe a tad negative) Have them check this when you get your aligment done. :yesnod: :) The stock camber settings produced terrible tire wear in my car. Part of the problem was probably due to the very hard OEM GY's. :confused:
[Modified by carpe dm, 12:19 PM 1/4/2003]
