First LS1 Engine rebuild
Old Jul 7, 2022 | 10:48 PM
tjervis's Avatar
tjervis
3rd Gear
Default First LS1 Engine rebuild
This is my first LS1 engine rebuild. My question is in the front of the engine block directly above the crankshaft and the front main cap there are two threaded bolt holes. Does anything go there? This engine was out of the car when I got it. My service manual does not show anything. Want to make sure before I put he cover on. Thanks for any help!
Old Jul 7, 2022 | 11:10 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Need to show a picture of what you are talking about.
Old Jul 8, 2022 | 06:06 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Might be holes for a timing chain dampener. Need to see a pic.
Old Jul 8, 2022 | 07:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
That's what I'm thinking, too. Not all the cars got the chain damper, so the holes were unused on some engines.
Old Jul 8, 2022 | 11:35 AM
tjervis's Avatar
tjervis
3rd Gear
Hope this pic went through
Old Jul 8, 2022 | 11:44 AM
leadfoot4's Avatar
leadfoot4
It did, and yes, it appears that those are the unused damper holes.
Old Jul 8, 2022 | 12:31 PM
tjervis's Avatar
tjervis
3rd Gear
Thanks for your help and peace of mind.
Old Jul 8, 2022 | 02:32 PM
grinder11's Avatar
grinder11
You're lucky you have them. Many blocks did not have the holes, and some that did weren't threaded/tapped. As for why, I dont know the protocol......
Old Jul 8, 2022 | 07:40 PM
vette4fl's Avatar
vette4fl
They come on two sizes depending on the bolt center to center measurements.
To First LS1 Engine rebuild
