Dyno Results at MTI
Old Jan 4, 2003 | 06:03 PM
Am I Badd's Avatar
Am I Badd
Default Dyno Results at MTI
I finally got my car dyno`ed today: A4,3500 Yank, 3:42 gear, Donaldson and programming by Ed W. Max. RWHP 320.1 / Max. RWTQ 371.9 and Max. RWHP 320.1 / Max. RWTQ 374.8
[Modified by Am I Badd, 5:10 PM 1/4/2003]
[Modified by Am I Badd, 5:12 PM 1/4/2003]
Old Jan 4, 2003 | 06:17 PM
Am I Badd's Avatar
Am I Badd
Default Re: Dyno Results at MTI (Am I Badd)
Can someone tell me what are these figures at the crank or flywheel?
Old Jan 4, 2003 | 06:31 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Assuming a 15% drivetrain loss, you're looking at 376 flywheel hp and 445 ft/lbs of torque. Those are some great numbers. :cool:
[Modified by CorvetteSS, 5:33 PM 1/4/2003]
Old Jan 4, 2003 | 06:54 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
nice numbers what's next :D
Old Jan 4, 2003 | 07:10 PM
Z06 Quin's Avatar
Z06 Quin
20% loss on the autos.....so divide 320 by .80 and that's your approximate FWHP....
Old Jan 4, 2003 | 07:50 PM
Don&Kelly's Avatar
Don&Kelly
I've always been told 20% for A4's & 15% for 6 speeds - so 320 RWHP / .80 = 400 Fly Wheel HP --- ahhh how sweet it is ...
Congratulations !! People spend lot's of $$$ trying to get to 400 Fly Wheel HP ...
:cool: :cheers: :smash: :seeya
Old Jan 4, 2003 | 09:03 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Dyno Results at MTI (Don&Kelly)
Sorry I don't buy into these formulas. I had 353 rwhp and changed my gear (3.42) to 3.73 and changed the T/C (PT-2400) to a ST-3500 , my next dyno I had 341 rwhp. Does that mean I lost hp at the flywheel, I don't think so!
The car didn't get slower at the track, it got faster! :yesnod:
[Modified by wallstAL, 6:06 PM 1/4/2003]
Old Jan 4, 2003 | 09:34 PM
jschindler's Avatar
jschindler
Make sure those are the corrected numbers. Uncorrected was significantly higher today. Either way that is some seriously strong torque. Not surprised though based on your last outing at Baytown. :cheers:
BTW, Mac, didn't get you voice mail till this evening. If you need me, try me again Sunday - I turn my cell phone off at night.
Old Jan 4, 2003 | 09:36 PM
jschindler's Avatar
jschindler
Default Re: Dyno Results at MTI (wallstAL)
What it means is that because of the changes you made, you now have different losses than a stock car does.
Old Jan 4, 2003 | 09:44 PM
J-Rod's Avatar
J-Rod
Lowering your gear ratio will result in a lower HP number measured at the rear wheels. This is an accepted fact when measuring force at the rear wheels. Its just like dynoing your car in overdrive. You will get a bigger HP reading. And if you dyno in 2nd it will read lower. Your car didn't loose HP.
Also, look at your TQ figures.
Same thing apples if you went from a 4.10 to a 2.73. You'd see about a 20-40HP gain with no other changes.
Rember your gear is multiplying torque. HP is a measure of acceleration. Lowering your gear ratio means it takes longer to accelerate your rear wheels. Its easier for your motor to perform this work under a load. But this is a no-load situation. So you see it as less power.
Old Jan 4, 2003 | 11:09 PM
Don&Kelly's Avatar
Don&Kelly
Default Re: Dyno Results at MTI (J-Rod)
:iagree: with J-Rod
My tuner said that every vette that he put 3:42's or 3:73's, or whatever, always dropped in RWHP, but got faster at the track .. I believe this has been debated before on the forum & they finally agreed that going from a 3:42 to a 3:73 would lower your RWHP - sometimes by quite a bit ...
Old Jan 5, 2003 | 04:14 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
So, flywheel (Crank) hp can not be determined by a generic formula and adding 20% to rear wheel horsepower for the A4 and 15% for the M6!!!!! Seems to me, there are many more factors involved in determining Flywheel hp. :yesnod: :yesnod:
Hope you guys get, what I am attemping to put into prospective.
If you add cold air with an intake (such as a Vortex), I would think the flywheel hp would increase and also rear wheel hp. But if you change to a taller gear, the rwhp should read less and the flywheel hp should remain the same.
[Modified by wallstAL, 1:25 AM 1/5/2003]
Old Jan 5, 2003 | 09:01 AM
Am I Badd's Avatar
Am I Badd
Default Re: Dyno Results at MTI (jschindler)
The figures I posted were corrected HP and Tq.
Old Jan 5, 2003 | 09:13 AM
jschindler's Avatar
jschindler
I was afraid of that :lol: :lol: :lol: :lol:
That's unreal torque!!! :thumbs: :thumbs: :thumbs:
Old Jan 5, 2003 | 10:35 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Yeah theat TQ is unreal.
That is more than alot of people with all the boltons and heads/cam!!!!
Are you sure it wasn't a spike in the graph or something?
Congrats!!!!
Old Jan 5, 2003 | 10:52 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
congrats on the #s :cheers:....can you post the graph :cheers:
Old Jan 5, 2003 | 12:30 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
The 3.73 changed your final drive ratio and doesn't give the same numbers as it did with the stock rearend, I changed to 390s on my M6 and it cost me about 5% on the dyno but is much quicker.
To Dyno Results at MTI
Old Jan 5, 2003 | 05:58 PM
Am I Badd's Avatar
Am I Badd
Default Re: Dyno Results at MTI (NEPTUNEBILL)
I`m not able to post from this computer the graph. I`ll try to get a friend of mind to do it.
Old Jan 5, 2003 | 06:48 PM
OhNiner's Avatar
OhNiner
:iagree: with J-Rod
A dyno pull in 2nd gear showed 285 hp, in 3rd I pulled 301hp.
Old Jan 6, 2003 | 10:38 AM
Mike TexaSS's Avatar
Mike TexaSS
Default Re: Dyno Results at MTI (Gardiner)
I amm Bad you got any mods done to your impy? Nice to see a fellow impster on the board and from H-Town who would of thunk it!
I got a few mods
