Clicking Relays
Old Jul 16, 2022 | 07:28 PM
DutchMagnus's Avatar
DutchMagnus
2nd Gear
Default Clicking Relays
Hello everyone, I just recently did an exhaust bypass mod when I was done I slapped the whole car back together and boom this clicking noise starts to happen when I started the car. the whole time from the passenger footwell there is a constant clicking coming from relays also I can not use my turnsignals they just bug out and my dash lights slightly flicker. One last thing every time I lock the car the alarm goes off. I did some research and some people say its the battery its not I put in a new one. Any other ideas.
Old Jul 16, 2022 | 07:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Clicking replays are normally caused by high resistance in either the power or ground side of a relay !!…start checking the relays in the IPC fusebox in the passenger footwell for the offending relay or relays !!
Old Jul 17, 2022 | 05:35 AM
VetteMed's Avatar
VetteMed
Any ground wires disconnected during the work you did? Sometimes a main ground lug left off can cause that kind of thing.
Old Jul 17, 2022 | 09:11 AM
mmartinez's Avatar
mmartinez
Clicking relays mean that the relays do not have full battery voltage across the relay coil, you said new battery but have you put a meter and measured battery voltage.
To Clicking Relays
