What is it?
Old Jul 19, 2022 | 08:25 PM
mmartinez's Avatar
mmartinez
Default What is it?
Doing some basic maintenance to my 97 coupe, removed battery and plate as well as wheel wheel cover to clean pcm connectors. I found a small rectangular plastic box with wires coming out of it, it was taped to the main wiring harness under the battery what is it?
Old Jul 19, 2022 | 09:50 PM
Randyramsey's Avatar
Randyramsey
Banned Scam/Spammer
Please post a photo
Old Jul 20, 2022 | 08:36 AM
mmartinez's Avatar
mmartinez
Sorry, put everything back together again, I thought somebody would just know what that little device is.
Old Jul 20, 2022 | 09:32 AM
1999corvettels1's Avatar
1999corvettels1
Could it be a skip shift eliminator? Is car 6 speed?
Bought one from Compliance Parts 4 years ago along with the LMC5, installed the LMC5, never put the skip shift eliminator yet, but I think the instructions said it’s installed near battery.
Old Jul 20, 2022 | 09:40 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
No, it’s installed on the transmission!!
Old Jul 20, 2022 | 09:45 AM
1999corvettels1
The CAGS-SKIP is the FIRST and ONLY available product that disables the 1-4 shift light!
AND
The CAGS-SKIP is the FIRST and ONLY available product you install without lifting your Corvette!
As described on the C5 CAGS Skip Shift System page, under certain operating conditions, the CAGS system will not allow upshifting from 1st to 2nd or 3rd gear, and will also illuminate the 1-4 shift light on the instrument panel. Virtually everyone who has driven a 6 speed '97-'04 Corvette has experienced this annoying system that often occurs at the worst possible time - under light acceleration from a stop, when you really need 2nd gear the most.
The CAGS-SKIP eliminates this CAGS (computer aided gear selection) skip shift function, and allows you to shift however and whenever you want!.
The CAGS-SKIP disconnects the Powertrain Control Module (PCM) from the skip shift solenoid and from the instrument panel 1-4 shift light, and reliably and safely substitutes signals that prevent the generation of error codes. In other words, your car thinks nothing has changed, but you'll never see or feel the original CAGS system again!
The CAGS-SKIP makes 3 connections to your Corvette:
  1. A fused connection to the positive post on the underhood fuse panel.
  2. A terminal that replaces an OEM terminal in a connector that disables the skip-shift solenoid.
  3. A CAGS-SKIP wire spliced to a wire located beneath the underhood fuse panel.
The CAGS-SKIP installation DOES NOT require raising your Corvette and crawling underneath to access the connector on the transmission! The CAGS-SKIP is easily installed under the hood, next to the battery.
The CAGS-SKIP and its installation have been designed to be as easy and foolproof as possible. No permanent modifications are made to your Corvette to disable the 1-4 shift solenoid, and to allow uninterrupted upshifting. The procedure to disable the instrument panel 1-4 shift light can be performed in two ways. Either cut one wire (quick and easy), or replace a fuse panel terminal (a little more time, but no cutting). Either way, this step is completely optional You can perform this step right away, months later or never. It's your choice. Regardless, the shift lockout will be gone forever!
Copyright © 2010-2014, Compliance Parts, LLC. All rights reserved. All trademarks are the property of their re
Old Jul 20, 2022 | 04:19 PM
Randyramsey
Banned Scam/Spammer
Probably an alarm or audio. Cant tell without a photo.
Old Jul 20, 2022 | 07:17 PM
mmartinez's Avatar
mmartinez
Thanks for the replies, still really do not know what that thing is, bought my 97 coupe in 2006, it is a M6 car and the cags skip shift had already been defeated. Next time I will post with a picture.
Old Jul 20, 2022 | 07:24 PM
Randyramsey
Banned Scam/Spammer
Follow the wires and see where it goes
Old Jul 24, 2022 | 02:48 AM
whatyacallit's Avatar
whatyacallit
BCM - Body Control Module
Old Jul 24, 2022 | 09:51 PM
SilverC54me's Avatar
SilverC54me
If it is a black box mounted to the PCM, then that is the TAC module.
Gary
Old Jul 24, 2022 | 09:54 PM
mmartinez's Avatar
mmartinez
Sorry it's not the BCM, the BCM is located inside the passenger footwell area.
To What is it?
