Locked steering
Old Jul 19, 2022 | 09:16 PM
97C5TW's Avatar
97C5TW
Cruising
Default Locked steering
Before anyone says it. I have already purchased and installed the LMC5 module. I also bought the kit with the unlocker tool. Now the kit did fix the annoying message on the dash that so many of us are familiar with. But the steering wheel “unlocker” tool has done nothing and the steering wheel is helplessly locked still I’ve tried a everything from jiggle the steering wheel vigorously, putting pressure on the steering wheel in both directions. Absolutely nothing. I tried to get it towed to a dealer and the flat bed took one look and said no way tool low and with a locked steering wheel he wanted no part of it!! Seriously does anyone have help for my desperate situation. My car is a ‘97 with 6 speed. thanks in advance
Old Jul 19, 2022 | 09:33 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
So this happen to me about 20 years ago, I literally had to jerk the steering wheel with enough force that I thought it was going to pull off the car but it freed it and was able to drive it to the dealer. That car was a 1998.
Old Jul 19, 2022 | 10:10 PM
wdcraig's Avatar
wdcraig
Perhaps reach out to Compliance Parts (the maker of the LMC5); I have found their customer support to be top notch. (855) 565-8388
http://www.complianceparts.com/index.html
Old Jul 19, 2022 | 11:01 PM
Dads2kconvertible's Avatar
Dads2kconvertible
So you have this unlocker tool and it isn't unlocking the column?
http://www.complianceparts.com/lmc5unlocker.html
Note: If your steering column lock motor is severely jammed, or has failed in the locked position, not even the LMC5 Unlocker will be able to unlock your steering column. Fortunately, this seems to be a very rare occurrence, and the vast majority of all C5 steering columns can be easily unlocked. We recommend that you contact a knowledgeable Corvette dealer or Corvette service professional in the event that your column will not unlock, even after using the LMC5 Unlocker.
Based on that note I would try and hold the steering wheel in a position that isn't putting any pressure on the locking pin, then try the unlocker. Good luck.
Old Jul 20, 2022 | 11:46 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Have you done the brown wire mod? I'm guessing you have, but I figured I'd ask to be sure. Good luck!
Old Jul 20, 2022 | 12:14 PM
I agree on talking to Compliance Parts and see if they can help.
Otherwise, good luck getting the wheel to release.
Old Jul 20, 2022 | 10:15 PM
wrmiles's Avatar
wrmiles
Happened to me.
I contacted Richard at compliance Parts. He advised to undo the steering column shroud (not real easy) and tap on the lock with a screwdriver and hammer.
That worked.
Old Jul 21, 2022 | 08:23 PM
mmartinez's Avatar
mmartinez
Happened to me as well due to low battery, I really jerkef the steering wheel violently to get it to unlock.
To Locked steering
