Code "P0500C" Means what?
Old Jan 4, 2003 | 10:32 PM
BLACKONBLACKZ06's Avatar
BLACKONBLACKZ06
Default Code "P0500C" Means what?
10 pcm error code "P0500C" is the only code showing.
The tech chart doesn't show what the "C" represents.
And what exactly is "P0500 VSS Circuit (M/T)?" :seeya
Old Jan 4, 2003 | 11:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Code "P0500C" Means what? (BLACK/BLACKZ06)
I'm not sure what that code means (other than the code description you mentioned), but the "C" means it's current and still an active fault.
If it were an "H", that would mean History, and no longer showing a fault.
Anyways, ttt for ya.
:cheers:
Old Jan 4, 2003 | 11:15 PM
BLACKONBLACKZ06
Default Re: Code "P0500C" Means what? (Y2Kvert4me)
Thanks Y2K.... :yesnod:
Anybody "P0500 VSS Circuit (M/T)?"
Vehicle Speed Sensor (VSS) Circuit?
[Modified by BLACK/BLACKZ06, 10:23 PM 1/4/2003]
Old Jan 5, 2003 | 12:41 AM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
I e-mailed the service manual pages, but after re-reading your post, you already had them :bb .
Old Jan 5, 2003 | 06:30 PM
DanSRV's Avatar
DanSRV
Cruising
The VSS(vehicle speed sensor) is a plastic plug in type sensor on the tranny, there are two plugs which I know of that send MPH info to the computer. One works to display the HUD MPH, and the other goes to the acutal needle gauge. Are both of your speedos working? Do your fuel settings in the dash register properly? i have a few photos of where they are located if you'd like. The "C" means the code is current.
dan
Old Jan 5, 2003 | 11:31 PM
BLACKONBLACKZ06
Default Re: Code "P0500C" Means what? (DanSRV)
DanSRV...
Don't have a HUD, speedo and fuel gauges work fine... :confused:
The Z is headed into the shop this week for another issue, I will have them take a look at the P0500 code also. I believe it should be covered by warrenty...
It's good to know thats all it is though...thanks :seeya
Old Jan 5, 2003 | 11:53 PM
gojo's Avatar
gojo
Have you tried deleting the code to see if it comes back?
How do you like the partition?
Old Jan 6, 2003 | 05:31 PM
BLACKONBLACKZ06
Default Re: Code "P0500C" Means what? (jfpilla)
Yepper...deleted all codes....even disconnected the battery once...
Still P0500C....
Partition is great, separated the trunk junk from the passenger area and a little quieter...but with the Borla it's never quiet :flag
To Code "P0500C" Means what?
