Clutch recommendations for a base C5?
Old Jul 24, 2022 | 01:48 AM
acefominC5's Avatar
acefominC5
Default Clutch recommendations for a base C5?
Related to my other thread. Clutch loses hydraulic pressure & puts car halfway back in gear. Replacing master in a few days but preparing to do a full clutch job if it turns out to be the slave cylinder.
I Need the aftermarket clutch to be:
-street performance type of clutch
-lighter than stock
-sturdy (can take daily redline shifts, drift few times a week , burnouts etc )
-not ride too jumpy
-not too expensive
I think the bite point on the stock c5 clutch is too wide and the revs rise/drop too slow. Find myself slowing my shifts down to match the revs proper. However I don't want to have to work surgically precise with my left foot to just keep the engine from stalling. Just a bit less than stock on this part would be perfect.
Of course I don't expect anybody to go look for an exact clutch like this that would fit all the points I listed, but maybe this would help someone give a few quick recommendations for good brands or specific clutch.
I know a lot of people put in the ls7 clutch in the c5 but I read that it's heavier, that's the opposite of what I need.
Thank you guys so much , so far the help I've gotten from the community with the issue I've been having is outstanding . Very glad I joined this forum
Old Jul 24, 2022 | 04:16 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
RST
If you're shifting fast have you tried a lighter flywheel before? No thought in the left foot, just hold 5-10% on throttle to rev match right into gear on downshifts.
Old Jul 24, 2022 | 11:11 AM
Supercharged111's Avatar
Supercharged111
My 2 suggestions are aluminum flywheel with new stock Luk clutch to maintain stock pedal effort or a Spec Stage 1 (which I have) 10.5" with aluminum fw/pp. It's 20# lighter than stock, the RPMs drop much quicker, but the first 3 gears pull noticeably harder. The C7 multidisc setup likely offers a similar return, but I can't speak to it.
Old Jul 24, 2022 | 11:13 AM
acefominC5's Avatar
acefominC5
Originally Posted by Tusc
RST
Yes, I did think about this, definitely will get lighter flywheel when I get clutch done
Rst clutch I looked at it, it's a good clutch, but twin disk clutch that can take up to 800 hp is too much, I don't plan on putting a big turbo under the hood or nothin.. However still might do it, tempting fs
Any downsides to over-clutching the car ? If it's really that good extra $500 won't hurt
And how do I make sure that the flywheel I pick matches the clutch?
Old Jul 24, 2022 | 11:33 AM
Tusc's Avatar
Tusc
Bear with my logic on this one.
Clutch change on these cars is not easy or quick.
You sought factory feel or lighter. RST provides this.
You mention beating on the drivetrain, but then counter my suggestion saying this clutch is rated to 800hp as though thay were a bad thing. Lighter feel, more capacity to hold is a good combo.
I run one in my daily driver 99 coupe. For about 40k miles it also had 10psi and 500rw. For the next 35-40k it has been NA. Never an issue with the clutch. Though when NA I did manage to shear the 10mm bolts at the rear of the driveshaft. Thr clutch is still ok. All the launches, highway pulls, all the torturous stop/go traffic and commuting for 7 years and that bugger is still going strong.
That's why I recommended it.
In the 99 it is paired with a Fidanza lightweight aluminum (11#) flywheel. I have an RXT going in my Z06 build which has a McLeod lightweight steel (13.5#) flywheel. Both better than factory which was close to 24#. If you have not used a lightweight piece before and you enjoy quick shifting or insta-rev match going through twisties you will love it.
Of course, results may vary. And there are other competent clutches out there.
Old Jul 24, 2022 | 11:35 AM
666lisa's Avatar
666lisa
Down side is your going to be kicking yourself in the *** when you decide to mod later. Many clutches out there that feel like stock and hold up to 1k hp. Friends ***'s are still hurting years later not upgrading. Its not cheap changing a clutch if you don't do it yourself.
Old Jul 24, 2022 | 12:01 PM
acefominC5's Avatar
acefominC5
I want an e36 m3, I am not planning on keeping the Vette more than another ~3 years , I won't be modding it much . Perfect mid point would be a street clutch that holds 500 hp if I do decide to get a tune or somethin
I'd def get the RST otherwise , $400 difference is nothing considering the labor alone is like $1600
This repair got me turning my pockets inside out already to be honest
Old Jul 24, 2022 | 02:01 PM
Randyramsey's Avatar
Randyramsey
Banned Scam/Spammer
I’ve done quite a bit of research. When the time comes, I’m going with a Monster twin disc. Monster comes recommended by almost all of the major tuning shops out there.
Old Jul 24, 2022 | 02:40 PM
Tusc's Avatar
Tusc
I wonder what the margins are with Monster vs others for the tuners putting money in their pockets. It's a brand I'd consider if I didn't already trust / respect the RST and have the second car come with a fresh RXT already installed. I'm not brand loyal there.
Old Jul 24, 2022 | 03:03 PM
acefominC5's Avatar
acefominC5
Probably going with the RST, it don't matter, you guys are right . 1600 just to pull all of that , rather install the best part I can.
However the kits I found don't include the pilot bushing and throw out bearing. Which ones should I buy?
The flywheel - read that the stock one is 23 lbs and that the lightest aftermarket ones are around 11 lbs. Going to go in between somewhere and buy a ~15 LB flywheel. For this weight, which flywheel material is best: aluminum or chromoly?
How do make sure it's compatible with the clutch kit? I know the tooth count has to match. What else?
Nd last thing, on summitracing the RST kit I found says in description , 'no mounting hardware included'. What is this supposed to mean?
Old Jul 24, 2022 | 03:13 PM
Randyramsey
Banned Scam/Spammer
The tuners that I know and have talked to wouldnt recommend a product to just pocket a few more dollars. These builds are $15k-$30k. A few dollars here and there on a $1500-3k clutch isn’t going to make a difference.
certain products are just the best.
monster clutch
Frankenstein heads
ati for balancers
arp for bolts
pro chargers for blowers
katech c5r for timing chains
dewitts for radiators
baer brakes
turn one for steering components
Old Jul 24, 2022 | 03:26 PM
Tusc's Avatar
Tusc
I can't knock solid reps. But not all are solo on the podium vs other large brands. And we're still talking short money.
Old Jul 25, 2022 | 12:57 AM
acefominC5's Avatar
acefominC5
Edited a reply above ) Let me know about the flywheel material. Which would be best, chromoly or aluminum if I never want to pull the car apart again like that? Which LTW flywheel is most durable & less likely to break?
And speaking of flywheel weight, stock one is 23 LBS, find myself delaying my shifts a bit to rev match. Is 15 the right weight, or is that gonna be too low ; approx by how much % would flywheel like that increase the speed that the revs drop at , and how much narrower will the bite point become ?
Old Jul 25, 2022 | 11:33 AM
LowcountryVette's Avatar
LowcountryVette
I’m about to buy an rst for my 99 that I daily as well. Any regrets with the aluminum flywheel on a daily? I see a good bit of stop and go traffic
Old Jul 25, 2022 | 12:29 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
When I had to replace my hydraulics I did the clutch at the same time even though it only had 37K miles. I used a Fidanza aluminum flywheel and stock LS6 Luk clutch. Its like 14lbs lighter than stock and noticeable is revs. Drives like stock on the street and no difference in pedal effort. For my stock LS6 with headers it has more than enough torque capacity and withstands the high RPM fast shifting on road course use.
Old Jul 25, 2022 | 12:47 PM
Tusc's Avatar
Tusc
None. You adapt quickly to the very slight difference. Then you instantly love the easy shifts when tooling along. The effect is magnified if you ever add a cam and a tune where the revs will drop faster. I will have gone lightweight fw on three cars now.
Old Jul 25, 2022 | 12:59 PM
LowcountryVette
Think thats what I’ll do then
To Clutch recommendations for a base C5?
Old Jul 25, 2022 | 01:39 PM
smitty2919's Avatar
smitty2919
I run a 10.5" Spec 2+ (you can get a less aggressive option if needed) with aluminum PP and matching Spec 10.5" aluminum FW. Saves almost right at 20lbs over stock LS1/LS6 combination. I have it paired with a Tick 3/4" bore adj MC (but that's not really needed). Car also has a cam/exhaust. No extra balancing needed, bolted in with no problems.
I use my car 80% DD and 20% autocross. My wife will even drive/race my car.
I have zero complaints with this setup. It it slightly louder at idle with the clutch not depressed. Anymore noise (smaller more race oriented clutch) I would be annoyed.
Old Jul 25, 2022 | 01:56 PM
acroy's Avatar
acroy
that sounds like a reasonable setup.
My car came with a Spec P-Trim Super Twin with 1,300 ft-lbs capacity and oversized TICK MC. PO had been planning a 1k+ whp FI build but did not follow through. It was ridiculous; maybe a skilled driver could drive it smoothly but I could not. I was essentially using the tires as the clutch. Went down to a stock sized MC but still terrible. Finally replaced it with a Mamo'd RPS carbon twin rated for about 700ft-lbs iirc. It still has a pretty narrow engagement window but much easier to get it going.
Old Jul 25, 2022 | 04:34 PM
smitty2919's Avatar
smitty2919
I don't have high HP needs which thankfully narrowed down my clutch selection. I looked hard at the new "at the time" Monster S Series twin which I understood it as a factor C7 PP with a custom machined FW to work in the C5. I liked the idea of "factory quality" but the price still seemed steep. All the McLeod/RPS etc were damn pricey for my needs.
A friend of mine that owns a speed shop local to me suggested the SPEC combo. All in his price I think I was ~$800. I also did OEM slave as well at the time. So far this clutch combo has given me zero issues. 20lbs lighter, under $1000 and dyno proven gains in midrange due to less weight...win win win.
