Need help picking valve springs
Old Jul 25, 2022 | 04:31 PM
Chris01Z's Avatar
Chris01Z
Default Need help picking valve springs
Long story short, just finished putting heads/cam/longtubes on my C5Z. On the dyno it fell flat on its face at 5500, peaking at only 408rwhp at 5700. LS6 peaks at 6k stock, so something's off. I'm running PAC 1218 springs with Yella Terra Ultralite 1.7s. I recognize this is a mistake, as its not nearly enough spring to manage the YTs. Cam Motion ground the cam and that was their assessment as well.
Cam specs: Cam Motion 222/250 .587/.579 133+3. They have given me 2 options:
1. Go back to stock rockers (with Trunion upgrade) and PAC 1219s, or 2) a good .660 lift dual spring and keep the YTs. Third option I think is obviously dual spring with OEM style rockers.
Thoughts? I've wanted to stick to a beehive because there's some school of thought that you want the lightest spring you can get away with for durability, etc. But I'm thinking maybe I overthought it (that's sort of a thing for me) and I just need to go with option 3 and be done with it.
Car will be mostly street/cruiser/fun with possible occasional HPDE.
TIA for the help.
Old Jul 26, 2022 | 08:54 PM
grinder11's Avatar
grinder11
TIA for the help.
If they're salvageable, I'd reuse the stock trunnions, in the stock rockers. In most cases though, they're missing a few needle bearings, or have been thrown away. Many of the "upgrades" are actually downgrades. I had a 232°/236°, .600" lift, on a 112° LSA, using Comp 26921 springs, with Ti retainers, on stock LS1 rockers, and never had a problem with the OEM trunnions. Just curious, a 222°/250° duration split is HUGE!! Why the big split? Plus, a 133° LSA??? I suspect some typo's here. One thing you must do to get accurate help is provide accurate info!! Anyway, I got the Comp "upgraded" trunnions for my LS7 heads, and found out the hard way they're like everybody says: NOT TOO DAMN GOOD!!! Id go back to stock rockers and stock trunnions. My opinion. Hope this helps......
Old Jul 27, 2022 | 10:57 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I too prefer the lightweight valvetrain. I would go with the BTR v2 trunnion upgrade on stock rockers and PAC 1219 springs. I run the stock rockers (stock trunnion) with PAC 1218 springs in my LS6 to 7400rpm no problem with stock cam. If I ever do a cam later on I will do stiffer springs and a trunnion upgrade.
Old Jul 28, 2022 | 08:26 AM
grinder11's Avatar
grinder11
To respond directly to you're question, I like dual springs over single. Probably in the minority on that one. Anyway-Best advice I can give you is to talk to someone at the cam grinder, AND at PAC. PAC makes some damn good springs. I've had PAC 1905 duals in my built LS7 for 8 years, 37,000+ miles!! I believe 1905 is too stiff for what you're doing. But give PAC AND the cam grinder a call. Who would know their products, and what is required, better than they do?
Old Jul 28, 2022 | 08:31 AM
Chris01Z's Avatar
Chris01Z
Thanks. I have talked to both. Cam grinder suggested PAC 1219s if I want to stay with a beehive (and OE rockers) or a .660 dual kit with the YTs. I've decided to ditch the YTs regardless though.
PAC says the 1218s are fine until 7k rom. After searching LS1tech extensively I've found several folks running 1218s with similar cams and spinning to 6600, 6800, even one to 7500! Also, the Sloppy Stage 2 and WS6store hot cam kits (both similarly spec'd) come with 1218s.
So I think I am going to at least try OE rockers and leave the 1218s in there, at least for another dyno session. May still swap them out for peace of mind of a dual spring, but trying to trust the opinion of the spring manufacturer and not overthink it for once LOL.
Old Jul 28, 2022 | 08:40 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Cam specs: Cam Motion 222/250 .587/.579 133+3 What is this cam designed to do?
Old Jul 28, 2022 | 08:41 AM
Chris01Z's Avatar
Chris01Z
Sorry, typo. Its 113+3.
To Need help picking valve springs
