Alignment specs for C5
Old Jan 5, 2003 | 12:26 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Alignment specs for C5
I need the specs for street driven C5. Thanks in advance!
Old Jan 5, 2003 | 04:10 PM
te51cle's Avatar
te51cle
Default Re: Alignment specs for C5 (NEED FOR SPEED)
These are the specs for the Z06 and Coupe/ Convertible. The only difference between them that I can see is that the Z06 has -0.5 degrees more camber. I hope they help. If you copy them into a word processor document and convert them to Courier font they'll be easier to read.
C5 Coupe Wheel Alignment Specifications
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe +0.14 to –0.06 degrees +0.04 degrees
Front Sum Toe +0.28 to –0.12 “ +0.08 “
Front Individual Camber +0.50 to –0.70 “ -0.20 “
Front Cross Camber +/- 0.25 “ within 0.50 “
Front Individual Caster +6.4 to +7.4 “ 7.4“
Front Cross Caster +/- 0.25 “ within 0.50 “
Steering Wheel Angle +1.0 to –1.0 “ 0.00 “
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe +0.09 to –0.11 degrees -0.01 degrees
Rear Sum Toe +0.18 to –0.22 “ -0.02 “
Rear Thrust Angle +0.10 to – 0.10 “ 0.00 “
Rear Individual Camber +0.32 to –0.68 “ -0.18 “
Rear Cross Camber -- within 0.50 “
Z06 Wheel Alignment Specifications
Front Individual Camber +0.50 to –0.70 “ -0.70 “
Front Individual Caster +6.4 to +7.4 “ 6.9 “
Rear Individual Camber +0.32 to –0.68 “ -0.68 “
[Modified by te51cle, 3:16 PM 1/5/2003]
Old Jan 5, 2003 | 04:35 PM
NEED FOR SPEED
St. Jude Donor '07
Default Re: Alignment specs for C5 (te51cle)
Thank you ,sir!!!!!!!!!!!!! :seeya
To Alignment specs for C5
