Any column lock experts out there?
Old Aug 3, 2022 | 01:52 PM
rob62's Avatar
rob62
Default Any column lock experts out there?
Happened finally on my 01Z. Have the LMC5 with unlocker but the unlocker is not working after many tries. Continued with the install to get the car back in the garage. Good news is the dash warning is gone. If I can just get that dam wheel unlocked !!
Old Aug 3, 2022 | 02:17 PM
Smoken1's Avatar
Smoken1
Call Richard at compliance parts I'm sure he can help you out
(855) 565-8388
Old Aug 3, 2022 | 02:44 PM
rob62's Avatar
rob62
Thanks I did. 5 days no call back.
Old Aug 3, 2022 | 03:21 PM
wrmiles's Avatar
wrmiles
I had that happen. Richard advised to undo the column shroud (not real easy) and tap on lock with a screwdriver and hammer. Worked.
Old Aug 3, 2022 | 03:47 PM
mmartinez's Avatar
mmartinez
Try jerking the wheel violently back and forth, worked for me once.
Old Aug 3, 2022 | 04:42 PM
rob62's Avatar
rob62
Thanks, I tried the wheel back and forth thing. Funny, the violence came natural.
Old Aug 3, 2022 | 04:43 PM
rob62's Avatar
rob62
If I could find a step by step somewhere ,this is what I think I need to do.
Old Aug 3, 2022 | 08:56 PM
1999corvettels1's Avatar
1999corvettels1
Also is your battery low?
Maybe trickle charge overnight and try again, not sure if battery voltage matters now you have the LMC5 installed, but couldn’t hurt to try.
Last time I got stuck summer 2018 at theater, had gf pick me up, pulled battery and took home and charged, it was weak from not driving much.
Went back about 1:30 am hoping nothing happened to my car, had to get wild with steering wheel and kept pulling key and turning back to on, got it broke free, parked car in garage and didn’t drive again until LMC5 installed.
At least your car is safe in garage!
Old Aug 4, 2022 | 09:27 AM
rob62's Avatar
rob62
Yes. I put a new battery in 2 months ago, thanks.
Old Aug 4, 2022 | 11:01 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
A new battery doesn't necessarily mean a fully-charged battery.
Even if the new battery were fully-charged it can easily lose a significant amount of charge over two months if, for instance, you're dealing with a parasitic drain.
At the very least check your battery voltage at its terminals with a volt meter.
dan k.
Old Aug 4, 2022 | 05:39 PM
CaliforniaJack's Avatar
CaliforniaJack
The column locked on my 2000 Corvette.. After a few hours wasted trying to break it loose, I just started to take the column apart. I spent about 2 1/2 hours to get to the pin module and determined that the module was shot. I took the module (just a few metal parts) apart and threw the pin away. Two hours later everything was back together (except for the troublesome pin). Problem permanently fixed.
Old Aug 5, 2022 | 08:34 AM
rob62's Avatar
rob62
Thanks. Looks like that's what I'll be doing once the temperatures drop a little.
Old Aug 5, 2022 | 12:09 PM
Darrell98's Avatar
Darrell98
Any chance you could post a procedure ? Thanks
To Any column lock experts out there?
